engine knocking, wondering if serious???
Old 01-09-2014, 04:55 PM
black98_ls juan's Avatar
Default engine knocking, wondering if serious???
Recently my car has had a bit of an issue with oil pressure, when I first got the car about 3 months ago it made 40psi at idle warmed up to 180° like every other ls1 ever. But about a week ago it suddenly dropped to 20psi at idle warmed up, and I couldn't get it to make above 40psi at any rpm. I changed the oil in it about a month ago and it made great oil pressure after that. I know 20psi should be fine but since the drop in pressure, there is now a noticeable knock at idle ans any rpm.and I know its not from the lifters, its more then a tick and its never had a problem with piston slap once it warms up. Any help would be appreciated.
Old 01-09-2014, 04:58 PM
HCI2000SS's Avatar
Is the noise louder towards the top or bottom of the motor?
Old 01-09-2014, 05:03 PM
I'm not quite sure, tonight I'm going to take a closer look at it, I haven't touched the car for 5days
Old 01-09-2014, 05:06 PM
HCI2000SS's Avatar
Yeah if it's coming from the bottom that's probably not good lol
Old 01-09-2014, 05:14 PM
Bottom end knocking would be rod bearings? Its got 147,000 on it never knocked, had the lifter tick, but now with loss of oil pressure its pretty bad. Also, about 3 yes ago the car had spray and made quite a few passes down the track, other then that its never been ran very hard
Old 01-09-2014, 06:50 PM
baronsmith98's Avatar
Does it have the factory oil pump still in it? I would probably go ahead and change it out
Old 01-09-2014, 07:29 PM
yep, its a 98 with stock pump, i think im gonna try to get a ls6 pump in this weekend. i just got done driving it for the first time in about a week, it sounds more like the lifters ticking but really exaggerated compared to when it runs normal pressure, so its not so much a knock i guess. is there iny simple fix to stop lifter tick? or do i need new springs?
Old 01-09-2014, 09:05 PM
chevybayboy's Avatar
Videos might help
Old 01-09-2014, 10:15 PM
fruitsalad's Avatar
Something blocking oil galley not allowing it to get to the top end?
Need video to tell.
Old 01-10-2014, 07:01 AM
That's MISTER MODERATOR
Paul Bell's Avatar
How many miles on this 1998 car? What oil & oil filter is currently used?
Old 01-10-2014, 08:24 AM
ss performance's Avatar
A knocking engine is never a good think.
Try to isolate where the knock is coming from maybe take to a professional to help diagnose.
Old 01-10-2014, 12:53 PM
Last night I got underneath the hood while it was running and I revved it up, its sounds nothing like a knock just sounds like the lifters are dry and ticking loudly. I guess I was kinda exaggerating the knocking cause i didn't know what it was in the beginning. I'd still like a tip on how to get them to quit ticking so loudly.
Old 01-10-2014, 12:59 PM
You said your oil pressure dropped.
Sounds like a oil pump.
Old 01-10-2014, 04:31 PM
147,000, and k&n oil filter with Napa 10/30 weight. Oil got changed a month prior to this oil pressure issue
Old 01-13-2014, 03:53 PM
tashspop's Avatar
is knock going half engine speed or full? does it follow rpm increases? push on your push rods to see if there is a collapsed lifter. you shouldn't be able to push them in by hand.
Quick Reply: engine knocking, wondering if serious???
