Crankcase evac, from valvecovers to header collector?
Old 05-10-2004, 05:41 PM
Black Sunshine/ 00SS's Avatar
Default Crankcase evac, from valvecovers to header collector?
Anyone try this yet? I've been looking through old magazines to get some testing results on this. Supposed to seal up the rings and ventilate the crankcase. Thus producing more power. Any thoughs on this?
Old 05-10-2004, 06:01 PM
KGSloan's Avatar
a bunch of my 5.0 mustang buddies run these setups. they all seem to like them. they claim you can get a noticable power increase from it.
Old 05-10-2004, 06:06 PM
CHRISPY's Avatar
It will not work without open headers. ANY amount of backpressure will negate the effect.
Old 05-10-2004, 06:16 PM
The old school guys I know run it, with a muffler. I'd be looking for max results on nitrous anyway, which would be wide open exhaust.
Old 05-10-2004, 08:45 PM
Cricket99SS's Avatar
Friend has a draft tube in the collector on his old Malibu with mufflers. The end of the hose has so much vacuum it will suck in the skin on your arm if you stick it up to it. Now mind you, these are sprint car mufflers so they are a straight through design. Like Chris said, if you have a twisty cat-back running it might not get you the vacuum you want.
Old 05-10-2004, 09:03 PM
Slow Z28's Avatar
true duals with dumps work good then?
Old 05-10-2004, 09:10 PM
FEAR THE LS1's Avatar
I thought about doing this to evac pressure from the valve cover to my headers, but I am running a true dual 3" xpipe axle dump exhaust. I couldn't see how I would get enough vacuum with this setup so I decided to do it the right way and am installing a Moroso 3 vane vacuum pump with my new motor. I'll take some pics when I'm done.
Lee
Old 05-10-2004, 11:48 PM
Z06PSI's Avatar
I have the same x-pipe setup (longtubes, 3", dumped)....I want to try it. What size of a line are we talking about here. I am thinking 02 bung and that way I can cap it up if it doesn't work..... I also have C5R valve covers to boot. Maybe using 1 valve cover per collector..???? tell me I am full of **** or encourage with some education. either way.....
Old 05-11-2004, 12:13 AM
GPowrie's Avatar
I am going to try evac on my setup. I am having baffles welded in to C5R valvecovers and running -10 lines to the headers. The car will be running by Sunday but will not be tuned for at least a week after that. I will keep you guys posted on the results.
Old 05-11-2004, 05:54 AM
BTL FED's Avatar
If I remember right GeorgeC ran this setup, do a search under his name you might find some info
Old 05-11-2004, 10:06 AM
My evac lines are -12 from the valve covers.
Quick Reply: Crankcase evac, from valvecovers to header collector?
