LQ4 408 Tuning?
Old 01-30-2014, 11:23 AM
Fast 95 Z28's Avatar
Default LQ4 408 Tuning?
So heres the scoop. I built an LQ4 408 and its running very rich as you can see in the picture I attached. I'm wondering if anyone knows which size jets I should run? I'm not sure what jets are currently in the carb as I bought it used and just slapped it on the car. Not sure if my small air cleaner is causing the super rich condition its a 10" air cleaner. I'm only running a 10" cleaner, because thats all that fits in my shaker scoop. I'm at sea level the combo ran an 11.48 @116.64 second pass. I'm happy with the E/T just thought it would trap more MPH. Heres the specs...
2003 Lq4 408 stroker
10.8:1 SCR
8.5:1 DCR
.037" quench
Stock untouched LS3 heads 821 castings
Forged -8cc wiesco pistons
Forged callies compstar crank
Forged eagles 6.125" rods
ARP 2000 rod bolts
Clevite bearings
231/242 @.050" .617/.615" 110LSA cam
Lunati Gold Dual Valve Springs (.660 lift)
Untouched L92 Victor JR. intake manifold
Quick Fuel 750 cfm double pumper mechanical secondaries (Q750)
LS7 Lifters
7.400 hardened pushrods
1 7/8" Dynatech Long Tube headers
NGK TR55 plugs gapped at .050"
3" X pipe into 2.5" Sweet Thunder mufflers
3000 stall converter
TH400 Transmission
3.73 rear gear with 275/60/15 when racing
Shifting at 6800rpm, redline 7000rpm
Launching at 2600rpm foot brake.
34* degrees of timing.
Engine is in a 1970 firebird weighing probably 3300 pounds.
Heres the link of the 11.48 pass.
Attached Thumbnails LQ4 408 Tuning?-spark-plug-408.jpg   LQ4 408 Tuning?-0712021454a.jpg
Old 01-30-2014, 11:29 AM
99wssixm6's Avatar
Humm Not really sure....what jets are in it now?
Old 01-30-2014, 11:41 AM
Not really sure, I bought the carb used and just slapped it on the engine. I thought I would try and ask before tearing it apart. Was just wondering if anyone else have a similar combo with experience.
Old 01-30-2014, 01:00 PM
Old Geezer's Avatar
Try the carb forum??
Quick Reply: LQ4 408 Tuning?
