Do I have to modify anything for Double row timing set?
Old 05-11-2004, 02:31 PM
98Blubrd's Avatar
Default Do I have to modify anything for Double row timing set?
I am about to do my cam swap and i thought i heard something about having to modify ASP pullys for a double row timg set. I have the rollmaster timing set and still have stock pully. Should everthing clear the timing cover and oil pump? Thanks.
Old 05-11-2004, 02:36 PM
HumpinSS's Avatar
If you have an ASP pulley that has a DOM after Aug 2003 then you are fine
https://ls1tech.com/forums/showthrea...&highlight=ASP
Old 05-11-2004, 04:11 PM
robertbartsch's Avatar
I had to drill the cam buttom hole a tad in my Rollmaster double sprocket so the cam would fit...you also need to install spacers in the oil pump...
besides that, everything should fit....
you should use a degree wheel and dial indicator ...
