My build 396 cid on E85 w/ 14:1
Old 02-06-2014, 11:33 AM
DREAMZ28's Avatar
Originally Posted by 98TransAmWs-6
Thanks! Catted y pipe because virginia requires cats if I want to drive it on the street at all but I plan to gut them so it looks like I have cats. Not sure what you mean by Kooks merge? I have debated getting a 4" merge collector, is that what you meant?
A bit off topic but I was under the assumption that our state stated any aftermarket exausht is illegal, unless is a factory replica/replacement?
And I've never been checked for cats before during a state inspection, at least I never saw them check.
Old 02-06-2014, 11:49 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Very interesting build. Looks VERY similar to my own personal car (396 LS6) minus a couple points in compression and I'm on premium pump gas. I'll be interested to see how it does. Cam is almost identical to mine. I'd strongly suggest a cutout at the Y-merge as that loudmouth system will be holding you back.
Lonnie
Old 02-06-2014, 12:02 PM
98TransAmWs-6's Avatar
Not true. It might state that but in practice isn't enforced. I've had my LM1 and headers on for a couple years with no issues.
Lonnie
I am contemplating using a 4" mufflex catback instead of a cutout or True Duals eventually. However I might consider a cutout.
Old 02-06-2014, 12:08 PM
danieloneil01's Avatar
Just because it isn't enforced doesn't mean it's legal. I do agree that he's a bit paranoid. Anything done to the engine in most states is illegal and for OFF ROAD use only. Just slip the inspector a hundy and get that sticker.
Old 02-06-2014, 12:11 PM
Rise of the Phoenix's Avatar
If they don't look for cats, then how the hell do they tell if the exhaust is stock or aftermarket?
Old 02-06-2014, 12:14 PM
Didn't say it was legal I said it isn't enforced. Although I didn't know they don't check for cats as I never paid much attention to that.
Old 02-06-2014, 12:20 PM
my406cid's Avatar
What kind of additube will this motor have with a bore much smaller than the stroke?
Old 02-06-2014, 12:22 PM
My crank and pistons will be in tomorrow according to my tracking info.
A torquey one.
Old 02-06-2014, 12:24 PM
This is all going in your 98 WS6?
Post up parts pictures as you get them.
Old 02-06-2014, 12:36 PM
Yes it is going in my 98. Yeah I'll definitely post pictures up speaking of which here is the ls6 block disassembled. It only has 10k on it lol.
K1 stroker rods.
BTR springs w/Titanium retainers.
Old 02-06-2014, 12:39 PM
Looks nice. My WS6 came with the LS6 block from the factory.
Old 02-06-2014, 12:57 PM
  #32
I wish mine had but seeing as it is a 98 that is not possible. But I got a good deal on the shortblock, $350.
Old 02-06-2014, 03:05 PM
  #33
Yeah, good deal for sure. I was pretty excited when I found out mine had the LS6 block.
Old 02-06-2014, 04:50 PM
  #34
If you don't wish to go true duals then the 4" mufflex would be your best choice other than a cut out. I recommend the single in/out 4" system that dumps behind the bumper and not the dual. You can fake out a set of tips out the back and no one would probably ever know that the exhaust isn't run to the tips.
Lonnie
Old 02-06-2014, 06:34 PM
  #35
Lonnie
I might do that. I will have some time to figure out the exhaust though since the engine isn't even built yet.
Old 02-06-2014, 08:42 PM
  #36
garygnu's Avatar
what fuel pump and injectors will you use ? dose you pistons have valve reliefs ?
Old 02-06-2014, 09:52 PM
  #37
I am using Lonnies Double pumper fuel system which is two racetronix fuel pumps and 95# Deatschwerks fuel injectors. I do believe the pistons have valve reliefs.
Old 02-07-2014, 08:08 AM
  #38
BWZ_2k2Z28's Avatar
Where are you at in VA?
Old 02-07-2014, 08:56 AM
  #39
Fairfax, which is like 20 miles south of DC.
Old 02-07-2014, 09:17 AM
  #40
DREAMZ28's Avatar
Ahh, good to hear. I see loud cars around Hampton all the time, including a lot of cars that have dumped exausht.
Quick Reply: My build 396 cid on E85 w/ 14:1
