My build 396 cid on E85 w/ 14:1
This is going to be a high compression 14.8:1 421 cid build tuned for E85 only. I will post pictures as it progesses.
So here's my build:
Engine:
4.030 bore Iron Block
Wiseco 4.030" +3 cc domed pistons
K1 6.125" stroker rods
K1 4.125" crank
ARP main cap studs
TFS LS3 255 heads
ARP head studs
Tick Performance Custom cam
C5r timing chain
Melling High Volume Oil pump (blue printed and ported)
BTR .660 spring kit w/titanium retainers
Morel 5206 Link bar lifters
Chromoly Pushrods (length TBD)
Comp cams trunion upgrade
Cosmetic 4.06 bore .040 thick head gasket
14.8:1 compression
Induction:
Kooks 2" X 3" headers
Kooks 3" TDs
FAST 102 intake
NW 102 TB
Speed Density (4" smooth bellows)
FTP 104 lid
Fuel system:
Walboro 450 lph fuel pump
95# Deatschwerks injectors
E85
Brakes:
CTS-V brembos
R1 Concept rotors and Hawk HP+ pads
SS brake lines
Drivetrain:
Moser 9" wavetrac w/3.73 gears
Carbon Fiber or Chromoly driveshaft (haven't decided what company)
Precision Industries Vigilante 4000 stall
Built 4l60e or 4l80e
Suspension:
Bilstein shocks
Vogtland or Strano lowering spring
Double adjustable PHB rotojoints
Adjustable LCA rotojoints
LCA relocation brackets
PHB relocation kit
SFCs
Strano hollow sway bars
Adjustable A-arms
Road Race k-member
Solid motor mounts
Poly transmission mount
Tires:
BFGOODRICH KDW 275 35 18 front
BFGOODRICH KDW 335 30 18 rear
Wheels:
Ace Alloy Slick 18x9.5/18x11 (+53 offset)
So here's my build:
Engine:
K1 4.125" crank
ARP main cap studs
TFS LS3 255 heads
ARP head studs
C5r timing chain
14.8:1 compression
Induction:
Kooks 3" TDs
FAST 102 intake
NW 102 TB
FTP 104 lid
Fuel system:
E85
Brakes:
CTS-V brembos
SS brake lines
Drivetrain:
Suspension:
Bilstein shocks
PHB relocation kit
SFCs
Adjustable A-arms
Road Race k-member
Solid motor mounts
Tires:
Wheels:
The purpose is mostly track with a little street for just causing around. This obviously is not a DD. I am hoping for 500 rwhp but my tuner things I will be in the realm of 580 to 670 rwhp. The wide range is due to the E85 typically giving a boost of 20 to 30% hp from switching to it from 93 octane, so it varies up to 10%.
600 rwhp is my goal but anything over 500 I'll be pretty happy with. My ET goal is at least 10s. It is certainly doable on a 346 but you would need a much larger domed piston like +11 cc to achieve 14:1.
Thanks! Catted y pipe because virginia requires cats if I want to drive it on the street at all but I plan to gut them so it looks like I have cats. Not sure what you mean by Kooks merge? I have debated getting a 4" merge collector, is that what you meant?
I didn't know they did either until reading another thread last night. Only reason I've been looking is because I'm going to upgrade to bigger headers and figure 2" primaries and 4" collector would be great for my current mods, and for mods down the road. You could probably merge get a merge for the y-pipe and then run your LM1.
They have a y pipe that is 3.5 to a 4. I saw it on the WS6TORE. Are you talking about the collector on the header or the merge collector on the y-pipe? If the first yeah Kooks doesn't make one.
Yeah, just looked and they are not on there. There is a guy on here who has them. I'll try to find out where he bought them from.
EDIT: Here is the thread where I found out about the ARH headers.
https://ls1tech.com/forums/drag-raci...headers-2.html
