How much oil do you run with?
Old 05-11-2004, 08:57 PM
master of the "jack"stand
ChevyWeatherman's Avatar
Default How much oil do you run with?
I have heard that oil starvation is a big problem with LS1s, especially in high G corners, but I would think hard launches could starve the front of the bottom end. I have heard of guys running as much as 7 quarts with a stock bottom end and stock pan.
How much do you use?
Old 05-12-2004, 01:08 PM
Viper's Avatar
6 quarts, works for me in autox.
Old 05-12-2004, 01:27 PM
soundengineer's Avatar
5.5 + filter recommended
usually works out to be just under 6
If you run too much oil you can get a hydraloc situation....BAD BAD BAD...
Old 05-12-2004, 01:28 PM
chupr0kabra's Avatar
Same as soundengineer: 5.5+ filter recommendation.
-Mike
Old 05-12-2004, 02:16 PM
PREDATOR-Z's Avatar
6 with a truck filter
Old 05-12-2004, 02:47 PM
LSX Mechanic
Damian's Avatar
6 qts w/ a PF58 filter..
Old 05-12-2004, 02:55 PM
trackbird's Avatar
Me too.
Old 05-12-2004, 03:05 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
I run 1/2 qt over stock.
Old 05-12-2004, 05:57 PM
It looks like a full 6 quarts is going to put me 1/2 quart over stock. I think that is what I will go with from now on...
Old 05-13-2004, 12:00 AM
LS1TECH Sponsor
badpewter-z's Avatar
youd need alot of oil for it to hydrolock but with to much and can airate the oil as the crank spins creating air bubbles and once air is sucked into pump and pumped threw motor thats where the damage will start so yes you can have to much but 5.5-6 with filter and your good
Old 05-13-2004, 12:07 AM
Blacker's Avatar
6 quarts for the last 6 years.
Old 05-13-2004, 03:54 AM
deznuttzz28's Avatar
6qts. + pf59 filter
Old 05-13-2004, 05:09 AM
ZR2877's Avatar
I normally put 5.5 in when I change oil and filter.
Old 05-13-2004, 09:25 AM
mitchntx's Avatar
7 qts with a filter here. If you run AX with 6, you are really risking a rod bearing.
https://ls1tech.com/forums/showthrea...ght=starvation
http://frrax.com/rrforum/index.php?act=ST&f=8&t=1227&
Old 07-05-2004, 08:27 PM
PCG
PCG's Avatar
6 with the mobil 1 M1-206 filter.
Old 07-06-2004, 03:03 PM
Great links Mitch, I hadn't seen your post until now. I will definitely run more than 6 quarts if I plan on AXing or open tracking. Looks like 7 is a pretty good amount to run.
