What AI heads would match my cam?
Hey guys, I'm looking at getting heads from Advanced Induction to be good with my cam and intake I already have and on AI's website for my 241 casting heads they have 205cc, 219cc, and high compression 219cc...I was looking at some high compression 219cc with 62cc chambers and cometic .040 head gaskets to put me at 11.15 compression ratio but I'm worried that it would be too much for ls6 intake and mild cam. What AI heads and head gaskets (stock thickness or thinner like the .040) would be best with my current setup below?
my setup right now on my 2000 Z28 M6 is:
224/228 .581 .588 112lsa cam
Hardened chromoly 7.400 pushrods
Single beehive comp 918 valve springs
Pacesetter 1 3/4 headers
3 inch true duals w/ mangaflow mufflers
LS6 intake
373 gears
Made 392 rwhp and 375 ft lbstq on DYNO jet
Ps. Will be getting stock throttle body ported, 42 lbs injectors, LS7 lifters and LS2 lifter trays
LS6 intake
373 gears
This will be a very nice street combo with a ton of midrange torque/throttle response. The cam and intake you have are fine for now and won't hold you back. If you want to maximize every HP, you could always swap them later if you felt like it needed it.
Sweet, thanks for the responses guys. Their BTR .660 with titanium retainers look really nice but would that be too much for a .581 .588 cam?
This is my opinion as per my experience with their products.
I have the "revised" version of the 918 springs that hold .625 lift but I'll get some duals if needed. I'm just wondering if you can have too much of a spring for a cam with .581 .588 lift seeing how the BTR duals are almost .80 more than I got
No, not in this case. XER has a sharp lift variance (49) and springs are not chosen just by "lift" capabilities. Open and closed pressures are very important as well, as well as valve weight and rpm use.
Now if you paid meticulous effort to all installed valve height and everything is top notch, these 918s will work for awhile; but for street BTRs will last longer. I would run 918s on a drag setup and check them all regularly, but for street lots of things can wear out a spring really quickly.
I have used XER Compcam lobes for many years and they are sharp. Lift variance on them is 49 and from experience their dual 921 class is better in properly handling those ramps. (However they are pricey and BTRs are top notch for $$ spent).
Nope, never been. We either collect at the track, the atv park, or my house. Just a few of the old school Camaro guys that been at this a while.
