What bolts are most critical to torque when installing trans to motor
So im going to (weather permitting) be removing the trans out of our TA to replace the flexplate. At the same time im going to swap out the torque converter with a CircleD stall unit, installing some LT headers.. so with things coming off I just want to make sure I torque everything back to spec and not miss anything critical.
I have already found the torque specs for the following:
Flexplate to Crank
Flexplate to TC
Motor to Bellhousing
Headers to heads
Axle to U joints(Rear only) since not planning on removing the yoke from the front.
I believe that is everything critical when reinstalling.. just wanted to make sure I wasn't missing anything else that is important to torque down??
I do plan on cleaning all bolts that im reusing, chasing the threads to clean them out.. and using Loctite on everything.
Is there anything im missing?
I am replacing the rear main seal, so I need to get those specs..
Flexplate to Crank
Flexplate to TC
Headers to heads
The flexplate and torque converter bolts are the most important, the rest you don't NEED to torque down unless you really want to. As long as the other listed things are tight then you'll be good. It might be a good idea to clean off the dowels on the block for the transmission if they are dirty and put some anti seize on them. It'll make it easier if you have to remove the transmission again.
IIRC the rear cover is 18ft lbs. Do you plan on replacing the gasket for that? You should put some rvt on the corners of the cover to prevent any oil leaks. If you have never done the motor mounts, now would be the best time to do them, especially since the transmission is out of the way.
Take your time and good luck.
thanks guys for the additional things to do and watch for..
The motor mounts have never been replaced, I was reading early on when I was thinking of doing all this and seems easy and hard at the same time..
Does anyone have a actually good source for replacing them while I have the trans out?
I wanted to do them, but I have 1 weekend or really 1 day to work on the car before the neighborhood association decides to send me a letter... so I cant leave the car undone if I don't finish..
I mean if worse comes to worse, I can remove the trans, move it into the garage and do everything else I can , then lower the car and it would look like it was never touched until I get back to it..
I don't plan on rushing, just trying to take advantage of the time and items I need and want to do..
So would these work? or do I have to replace the entire setup?
http://www.summitracing.com/parts/en...w/make/pontiac
http://www.umiperformance.com/catalo...roducts_id=556
ColoradoSpeed has them 10.00 bucks cheaper
here is passenger side on my car..I have tubular K, but these should work fine with factory pedestal.
very nice mounts, almost to pretty to put on the car...
ok, the torque arm bushing not familiar with.. is that fairly easy replacement?
Is there only one or two? sorry for the dumn questions, but just want to make sure I order or buy what I need and not be short on parts or supplys.
Is this the one? http://www.summitracing.com/parts/en...w/make/pontiac
Starter to block is 37ft-lbs and make sure to use some silver anti-seize on those when you reinstall. The little dust cover surrounding the Starter shouldn't be more than ~10ft-lbs. I stripped mine just trying to get it tight.
I think someone already posted a link to LS1HowTo.com, that's pretty much it. But look into getting some integrated swivel sockets. You know, they have the head already on the swivel. VERY helpful for an auto due to the clearances.
I also lower my K-member a little to get the 4l60e out. Not necessary, but if you do, K-member bolts are 92ft-lbs for the smaller ones and 108ft-lbs for the longer ones.
everyone thank you very much for all the feedback, suggestions and information.. I hope the weather stays as nice as it is today this weekend so I can get it done or atleast almost done..
Something I forgot to ask else where.. everyone keeps mentioning to use the GM gasket for the header install.. is that GM header gaskets? or is it GM manifold gaskets?
Can I reuse the ones on the car now(manifold)?
Actually no, we got the speed engineering race version headers with the ORY, should arrive tomorrow.. I didn't order the headers with the GM gaskets, as everything I read mentioned using the existing gaskets or getting GM gaskets, but I couldn't find if it was meant as GM header gaskets or GM manifold gaskets
http://www.ws6project.com/user_stor/...ets-set-of-2-/
I found these torque arm bushings. is this what is being referred to above?
http://www.summitracing.com/parts/ens-3-1111r/overview/
If so, since ive never replaced them, and never really seen what it looks like under the car, do I need 1 or 2 since the link says they are sold individually
thanks, got under there tonight to check on the trans mount make sure I had already changed that before ordering the rest of the parts...and checked out the bushing...looks worn, so will be ordering it also.
