F13 Installed
Old 05-14-2004, 08:47 AM
35thss2's Avatar
Default F13 Installed
The cam install took much longer than anticipated but finally finished up last night. Hopefully will be getting a dyno tune next week
Car idled fine after letting it warm up for about 5 minutes
Here is a video clip of the cam right after we started the car, picture isn't great:
http://www.vanbeekglobal.com/35thss/FM13Untuned.MPG
Old 05-14-2004, 09:22 AM
94form2000z's Avatar
Cool.. what are specs on it?
Old 05-14-2004, 09:33 AM
HumpinSS's Avatar
230/232 58*/59* on either a 112 or 114
Old 05-14-2004, 09:34 AM
Cool. thanx
Old 05-14-2004, 09:51 AM
35thss2's Avatar
it is on a 114
really was surprised that there wasn't more lope
Old 05-14-2004, 10:00 AM
HumpinSS's Avatar
a 112 or 110 should sound really nice
Old 05-14-2004, 10:25 AM
Sweet Cheeks
Damage Inc.'s Avatar
Let us know when you get it to the track.
YsoFast's Avatar
The car sounds great!! That is the first time I have heard that cam in a car and I must say I am going to be happy after I get it mine in. Mine is still sitting here sitting in a box with a bunch of other parts that are going in the Iroc. What was the main reason for going with a 114 over a 112 in your setup? I went with a 114 to get the power range down to a more usable rpm level for street use.
Old 05-14-2004, 10:32 AM
35thss2's Avatar
I went with the 114 so I didn't have much lope and I gotta say after tuning I'll be surprised if you can tell I have an aftermarket cam in
Old 05-14-2004, 11:00 AM
Kurtomac's Avatar
Lower LSA brings your peak down buddy, for example i got the F13 on a 113 and have 2 degrees built in so my cam is on a a 111 intake centerline and it peaked at 6450, Gomers F13 was on a a 112 and had 2 degreees in it so he was on a 110 ICL and his peaked at 6300
heres a graph of my F13 with TEA stage 2 5.3s through a 12 bolt on 18 in rims
Old 05-14-2004, 11:14 AM
HumpinSS's Avatar
Mine is on a 110 with 4 built in i will let you all hear it this weekend after the install. By the looks of Kutomacs post I just built a tow truck
Old 05-14-2004, 11:51 AM
dvandentop's Avatar
sounds good install was alot of fun
atleast when we install one in my vette it better go smoother/crosses fingers
Old 05-14-2004, 12:38 PM
So are FMS cams cut with an XER type lobe? Are they as hard on the valvetrane as Comp cams with such lifts?
Old 05-14-2004, 01:08 PM
Kurtomac's Avatar
XER lobes are comp lobes, FMS cams are Cam Motion ground cams.....to make all the under the curve torque you must have very fast ramps(hard lobes) but these seem to be very stable in the upper rpms as well
Old 05-14-2004, 02:30 PM
Sweet Cheeks
Damn, I was set on an F11, but this F13 looks pretty nice. Does the cam shake the car much on a 114 LSA? I hate that racecar idle shake.
Old 05-14-2004, 02:32 PM
Kurtomac's Avatar
i dont know why but my old 2254 581 112 idled rougher than my F13 on a 113....not too bad if you ask me go for it on a 112
Old 05-14-2004, 02:35 PM
35thss2's Avatar
I actually had the F11 ordered and they couldn't get it to me in time for my dyno tune so instead of that I decided to go with the F13 and I'm really happy with the sound
I would think with tuning there will be very little lope, actually wish I had more now
also car doesn't shake much at all, when your in it you can't even tell
Old 05-14-2004, 03:41 PM
pdd
pdd's Avatar
i put the FM11 in on a 114 and you can bearly notice i have a cam in there
. i did have alot of idle problems but there tuned out now
Old 05-14-2004, 07:23 PM
Sweet Cheeks
Sounds good. I think I'm going to roll a F13 on a 114 LSA. Please let us know some track times when you get the car out. Thanks.
Old 05-15-2004, 04:52 PM
dvandentop's Avatar
2 more videos
http://sio.midco.net/dvandentop3/paul.mpg
http://sio.midco.net/dvandentop3/paul2.mpg
