Changed timing chain and lost oil pressure
Old 04-08-2014, 09:46 PM
01ta346's Avatar
Default Changed timing chain and lost oil pressure
Have an ls1 in my 2001 TA has a ms3 cam and we degreed cam to 108 and lost power so I pulled everything back apart and set timing back straight up and power came back up. Thought everything was good but now I only have 20lbs oil pressure at idle and 40 at higher rpms. I only loosened oil pan to get pickup off and my mechanic buddy said that using fealer gauges to set up oil pump was not necessary. It is the original pump with over 100k of shear abuse!!! Will a new pump installed correctly up my pressure again? Car only driven 25 miles sinse changes.
Old 04-08-2014, 10:00 PM
LS1Tech Sponsor
COSPEED2's Avatar
I would not drive it any further if you want to save extra damage. If you had higher oil pressure before and less now, it is likely installer error. You may have pinched the o ring.
We have the very nice and very popular Melling High Pressure pump available here if you want it!
Old 04-09-2014, 05:25 PM
yonerhottlt1's Avatar
The pump could possibly be on it's way out. That or the O-ring.
Old 04-09-2014, 05:50 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
I'd say o-ring.
Lonnie
Old 04-09-2014, 05:51 PM
baronsmith98's Avatar
Id go ahead and put a new pump in. Dont drive it
Old 04-09-2014, 08:17 PM
jrpimp00's Avatar
^^ Dont put a new pump it in.. Check your o-ring first.
Old 04-09-2014, 08:40 PM
KCS
Moderator
KCS's Avatar
Another vote for the o-ring.
Old 04-09-2014, 09:31 PM
01ta346's Avatar
I'm going to pull motor this weekend and change pump and o ring I have a set of 799 heads to install anyways so no big deal. Only takes me about 3 1/2 hours out and back in with heads/springs swapped and oil pump swapped in hell I,ve pulled this motor 3 times in 3 weeks now trying different heads/cam timing options. What is the best oil pump for a high mileage ls1?
Old 04-09-2014, 09:44 PM
I have a melling high volume it works great. 50 psi at warm idle and 75 psi at higher rpms
Old 04-09-2014, 09:49 PM
LS1Tech Sponsor
COSPEED2's Avatar
Not just the high volume will give you those pressures.
100k is a good life span for a stock oil pump.
Old 04-09-2014, 11:12 PM
chevybayboy's Avatar
I also have the milling hv cold I'm at 70-75 warm about 60-65
Old 04-09-2014, 11:56 PM
Gray86hatch's Avatar
The pump needs to be aligned.
Tim
Old 04-09-2014, 11:59 PM
LS1Tech Sponsor
COSPEED2's Avatar
My bet is o ring over alignment issues.
Old 04-11-2014, 12:34 AM
Krab's Avatar
My guess is pinched O-ring. Buy new one from dealer and tear it down to replace it. It sucks, but it's gotta be done. Let us know how it turns out.
Old 04-11-2014, 05:33 PM
01ta346's Avatar
I'm buying a stock GM pump and o ring for the fix and thinking about replacing lifters with ls7's but I don't think there is anything wrong with my original lifters except for having high mileage (136k)? What's y'all's thoughts on the lifters? I'm hoping the lightly ported 799 heads give me a few more ponys over my 853 heads. Would love for my car to make 420whp with the 228/232 cam that's in it. But seriously thoughts on lifters?
Old 04-11-2014, 06:04 PM
Darkman's Avatar
I would change the lifters. They are not like spark plugs that can easily be changed later.
Old 04-11-2014, 06:24 PM
LS1Tech Sponsor
COSPEED2's Avatar
We have a group purchase on the lifters for $90 shipped right now. Cant beat that.
Id rather use the 10295 melling in any replacement but thats just my preference though.
Quick Reply: Changed timing chain and lost oil pressure
