Complete Gasket Kits?!..
Old 04-30-2014, 02:18 AM
NateLS1Mustang's Avatar
Default Complete Gasket Kits?!..
Didn't really know what section I should have posted this question under so I just chose this section since gaskets are kinda "internal" lol.
Anyways, does anyone (company) sell a complete top end & bottom end gasket/seal kit? I am pretty sure I need every single gasket & seal there possibly is. Actually I know I need every single gasket/seal there is but I do not want to purchase them separately. I have yet to find a complete kit. Most of the gasket kits I find only include head gaskets, exhaust manifold gaskets, and intake manifold seals.. Those kits don't really help when I still need a valley cover gasket, oil pan gasket, water pump gasket, oil pump gasket (or o-ring??), rear main gasket, rear main seal, and I'm sure there are other gaskets that I am missing that I can't think of or I just literally do not know about. If I am missing any gaskets or seals that I haven't noticed then please tell me!
This is my first build so any help would be appreciated. When I got this motor, it was all torn down already with no gaskets. Everything else I have to put this monster back together except for the gaskets. Any help would be appreciated! Thanks,
Nate.
Old 04-30-2014, 06:46 AM
niscur29's Avatar
I used a.victor reinz complete.kit on my lq9 rebuild. included EVERYTHING needed to start from a bare block/heads. I didnt buy a single gasket/seal separate. Part number 953563vr I got it off eBay cheaper then anywhere else.
Old 04-30-2014, 07:55 AM
Rise of the Phoenix's Avatar
Maybe check out Texas Speed. That's where I got my gasket kit for a heads/cam swap. Or, you could go to your local GM dealership and they should be able to get you what you need.
Old 04-30-2014, 11:25 AM
.boB's Avatar
Rock Auto has gasket sets and master rebuild kits.
Old 04-30-2014, 11:29 AM
CHEVELLEPOSSE's Avatar
Summit for cheap
Old 04-30-2014, 12:35 PM
Thank you everyone for the replies. One more question, if I have the 3.905 Mahle -4cc pistons in, will I see any PTV issues using a .040 cometic gasket? The pistons drop my compression ratio to 10.25:1 with a stock .051 gasket and I'd like to keep my stock compression (10.5:1 Ls6) using a .040 gasket. Does anyone know if that would be a problem or will I not really know until I do some measurements?.. I'd also like to fit a pretty good sized cam in there as well so I don't want the .040 gasket to limit me to smaller cam choices...
Old 04-30-2014, 04:38 PM
NuckenFuts's Avatar
Complete gasket kit off ebay is what I used.
You always need to check PTV, no one will know for sure. If your heads are stock unmilled dont think it will be a problem. Just remember these pistons do come out the hole so if you mill heads, big cam things can get tight really fast.
If your looking for a cam call Geoff over at EPS and Im sure he will answer alot more of your questions or call some other sponsors on the site.
Old 04-30-2014, 04:43 PM
Appreciate the feedback and totally diggin the username NuckenFuts!
Old 04-30-2014, 06:07 PM
Kalehuawehe2646's Avatar
Iʻm also looking for a complete kit for my 241ʻs Iʻm putting on my 5.3 NNBS Tahoe...
Quick Reply: Complete Gasket Kits?!..
