ZO6 cam into a stock LS1
Old 05-19-2004, 01:35 AM
GTS346's Avatar
Default ZO6 cam into a stock LS1
Hello Everybody.
When installing a zo6 cam into a stock LS1 do you have to upgrade to LS6 pushrods and valves or can you get a way with standard items and change the springs?
Old 05-19-2004, 01:53 AM
I can shift faster than you.
Jason99T/A's Avatar
You need the '02 LS6 valvesprings at a bare minimum. I prefer the Comp 918s and 7.400" hardened pushrods. The stock pushrods can be re-used, though.
Jason
Old 05-19-2004, 03:32 AM
GTS346's Avatar
Will LS6 valve springs be ok in an LS1 head or should I get stronger springs when not using LS6 ligthweight valves.
In other words can I use LS6 springs with LS1 valves or will the weight of standard valves cause valve bounce or collapse? Anyone done so?
Does anyone know how much lift LS6 springs can take, what there rated at?
Old 05-19-2004, 06:36 AM
Restricted User
2001 Pewter WS6's Avatar
I think the LS6 spring is rated for .575" lift
Old 05-19-2004, 02:23 PM
cbota's Avatar
Originally Posted by GTS346
Hello Everybody.
I have been asking the same questions, people have told me the stock pushrod length is good, others have said you need the longer pusrods to make up for the shorter LS1 valves. I think the 7.4 PR are a little short but the 7.45 are a little long, which is better? Also a GM article says do not use the Z06 came w/o using the ligter LS6 valves, but many people have and had no problems. GM might say this because they are taking about the effects after 100,000 miles. I have done some research and was going to install the Z06 cam with the stock 7.4 PR w/ 2002 springs.
Old 05-19-2004, 05:52 PM
2001CamaroGuy's Avatar
go with the 7.400" pushrod. My reason for saying this is:
a) being shorter will keep the lifter pumped up higher (closer to zero preload)
b) 7.400" works fine (countless numbers of engines have run this setup)
The reason they say use the light weight valves is that lighter valvetrain means the valve springs don't have to be as stiff to hold the valve closed (easier on the springs). Again, the LS6 cam with LS1 valves and LS6 springs has been done MANY times and people don't seem to be having any problems. I personally like more valve spring pressure so would just step up to the 918s but thats just personal "makes me feel good" and is not a requirement.
Old 05-19-2004, 08:22 PM
ULTIMATEORANGESS's Avatar
just springs with this cam and ive been fine.
Old 05-20-2004, 04:11 AM
GTS346's Avatar
Can I reuse standard LS1 retainers?
Old 05-20-2004, 08:31 AM
As long as your using LS6 or Come 918 springs. They are DIRECT swap for LS1. There are some springs out there that will fit the spring cup (in the head) but have a different "top" so they take new retainers.
Old 06-26-2004, 06:50 PM
StxVenomz28's Avatar
im getting ready to do the same thing here, so all I need is the cam and new springs?
Old 06-27-2004, 09:50 AM
thats all youll need.enjoy.
Old 06-27-2004, 10:01 AM
MARKSZ71's Avatar
i used stock pushrods and 918 springs
Old 06-27-2004, 10:05 AM
rangerob's Avatar
i made 34 wrhp from just my Z06 cam and springs., It brought me up from 326 to 361hp, now with the headers and rt cats, and MTI tune i have 384wrhp. Thats along with all the usual bolt on's (lid, maf, pulleys). So i would say that cam is a good Mod to do if you like stealth.
