Who in here has used the metal rods from Home Depot to do your cam swap?
Old 05-19-2004, 08:59 PM
2000SLVR_Z28's Avatar
Default Who in here has used the metal rods from Home Depot to do your cam swap?
I am going to go this route, but not sure if it is 5/16 or 3/8 rods? Also, does it have to be D shaped or with the round ones work?
Old 05-19-2004, 09:21 PM
mike c.'s Avatar
i just did a cam and spring swap 3 days ago. i went to home depot and got two wooden dowel rods(yes wood)they are 5/16 and round they cost $4.00 they worked great.i just cut them 6'' longer then the cam and they slid in great. hope this helps.
Old 05-19-2004, 10:03 PM
mcflyz28's Avatar
I used aluminum tubing from work.
Old 05-19-2004, 10:12 PM
01350ss's Avatar
NEVER USE WOOD!!!!!! Always a small chance of breaking and loosing a piece in the motor, now all of a sudden your simple cam swap turns into a huge un-needed project.
Anyway, I used 5-16 aluminum rod from home depot, no problems. good luck.
Old 05-19-2004, 10:16 PM
Heavy Metal's Avatar
Hi,
I wasted my money on the "Tool", I REALLY wished I would have just gotten some aluminum rod afterwards. I could have bought a lot of beer with that money.
Aaron
Old 05-19-2004, 10:22 PM
Sweet! thanks for the replies. So, the round rod will work just fine?
Old 05-19-2004, 10:36 PM
P Mack's Avatar
Yes, round rod. I tried both the 5/16 rod and the 3/16 with velcro wrapped around it. The 5/16 worked perfect on the drivers side but for some reason it got hung up on the passenger side. So I slid in the 3/16 with velcro and it worked great.
Old 05-20-2004, 09:50 PM
mike c.'s Avatar
the wood 5/16 rod is not tight enough to put shavings in the motor.i pushed and pulled them in and out several times and they were perfect.
Old 05-20-2004, 10:27 PM
Blacker's Avatar
5/16's here
Old 05-20-2004, 10:30 PM
01_SuperSlow's Avatar
I used them. Although mine were 1/4 inch. They were a little on the loose side so next time I'll use the 5/16's. Even though the rods were in, I didn't even let 15 seconds pass from when I completely took out the stock cam to when I started sliding in the new cam.
Old 05-21-2004, 12:01 AM
BigTex's Avatar
I had the same issue of the passengers side rod only going in about half way before getting stuck. Drivers side worked perfectly.
