Harlan sharp rocker arms?
Old 05-21-2004, 04:00 PM
Quick 99's Avatar
Default Harlan sharp rocker arms?
how well do these hold up compared to yellow terra or other shaft mounted rocker arms, will they hold my g5x3 (probably but just asking). How is the quality like?
Old 05-21-2004, 05:39 PM
PREDATOR-Z's Avatar
From what i've seen in pics very nice. however I also saw a thread where someone had to trim the end rocker tails with 5.3 heads at the corners. I still wonder was this due to that particular casting or is this true with all 5.3's ???
Old 05-21-2004, 05:56 PM
pdd
pdd's Avatar
i have the HS 1.7 rockers with my fm11 cam. no problems here and the quality is top notch. its a shame to cover them up
Old 05-22-2004, 11:57 AM
LS1TECH Sponsor
Steve Burger's Avatar
I have HS rockers and 5.3 heads. No problems and I rev to 6800 at the track all the time. They were a drop in install. no trimming at all. They fit perfect and are great quality.
Old 05-22-2004, 04:20 PM
SStroked 410's Avatar
I will most likely go with the HS's
but I hear you have to use shims, those with them did you use shims?
Old 05-22-2004, 04:46 PM
lsx24's Avatar
I would be sure about the results before I run those. Actually I almost installed it but I'm going to hold off until I get a setup together.
Old 05-22-2004, 05:34 PM
ss rally red's Avatar
I also have the HS with a FMS F11 installed them in Dec. and have been through a dyno tune and almost 20 passes and daily driving, quaility parts as far as I am concerned.
Old 05-22-2004, 07:57 PM
C4VetteLS1's Avatar
Ive got them on 3 cars now and fit is perfect.
Just before/after dynoed one today on a stock head z06 with cam and all the bolt ons.
Going from stock 1.7 ratio to HS 1.8 Ratio (220/224, .530 lift @ 112 cam)
Before : 392 RWHP
After : 396 RWHP
with most of the gain being in the high rpms...
Old 05-23-2004, 10:01 AM
soundengineer's Avatar
https://ls1tech.com/forums/showthrea...=harland+sharp
had to clearance the rockers on my 5.3L casting #862
only slightly....
Old 05-23-2004, 01:02 PM
PREDATOR-Z's Avatar
only slightly....
Question: Why didn't you grind the corners on the head instead?
The reason I'm asking is i'm getting some HS 1.7 with PP 5.3's stage II.
If I would run into the same problem as you did, I wanted to check out other options beside trimming the rockers.
Old 05-24-2004, 12:39 AM
98 Silver Bullet's Avatar
I have had no problems. They were a little tight in some places though.
Old 05-24-2004, 01:21 AM
Flyer's Avatar
Looks like he installed the rockers wiht the heads on th ecar. If he owuld have ground on the heads the shavings would have gone straight to the pan.
Old 05-24-2004, 03:48 PM
Quick 99's Avatar
awesome, ordered mine today!
