Quick torqe spec question
I got NAL-12610046 gaskets and can't find anywhere the torque specs on it. Can anyone help?
http://www.summitracing.com/parts/nal-12610046
If it's new stock bolts it should be: (M11) 22 ft/lb initial pass,
Second pass 90*
Third pass: 2004 and later 70*
pre-2004 90* on the long and 50* on the short
(M8) bolts 22 ft/lb
Make sure you tighten in the correct order. LS1howto.com has a picture showing the pattern.
Second pass 90*
(M8) bolts 22 ft/lb
