I have a question on the power my car makes??
2000+ LS-1 ~75k miles on motor
FAST 102 intake and throttle body
FTP 104 lid
Tuned for speed density
Custom Cam 239/247 .624"/.624" 110+0
Yella Terra ultralite 1.7 rollers rockers
Stock 241 heads
10.33:1 static compression 7.58:1 dynamic compression
Katech Rod bolts
Accel 42 Lb Injectors
Racetronix Fuel Pump with hot wire
TSP 1 7/8 longtubes
TSP True Dual Exhaust
Tuned by Charles Barber ar JR racing in Greenville SC
Transmission
Stock Rebuild ~ 10k miles ago
McLeod RST Twin Disc Clutch
McLeod Billet Flywheel
PST 3.5" Aluminum 1000HP Driveshaft
Rearend
Moser 9" ~1.5k miles ($4,100)
Backbrace
Fill and Drain Plugs
Wavetrack Diff
35 Spline Axles with Extended Wheel Studs
4.30 Gear
Aluminum Center Section
Adjustable LCA Mounts
Swaybar Mounts
Suspension
Midwest Tunnel Mount Torque Arm
UMI Lower Control Arms
Energy Suspension Swaybar Bushings and Endlinks
Chrome ZR-1 Wheels Stock Front and 17x10 Rear
Front Tires NT05R 275/17s
Rear tires Mickey Thompson 315/35 17 drag radials
This is my setup. Car made 440/387 today in 94* humid weather. I've had several people say it has head work, but the runners look stock to me, still have the factory casting look. Is this a higher than normal number for the setup? It was not made just to see a number so no toying with the tune or anything like that. Timing was at 28*. AFR was right at 12.
FTP 104 lid
Stock 241 heads
Katech Rod bolts
TSP 1 7/8 longtubes
Transmission
Rearend
Backbrace
Wavetrack Diff
4.30 Gear
Swaybar Mounts
Suspension
I guess I should've worded that better. The dyno is on par with other cars. I think mine is high too but I looked into the runners on intake and exhaust and compared them to a friends stock heads that just came off his car and they look stock. Idk if they're milled or anything, but I don't think that would still put it where it is. The car made 417/379 with ls6 intake, stock throttle body, slp lid, stock maf, stock rockers, and 1 3/4 headers.
I would be curious to see what it would make with a PRC 2.5 LS6 head on it but I'm gonna build a 408 for it and wait to choose heads then. I've got a nitrous kit on it just getting the stock motor where I want it and I've got some chassis/lightening to do now. It's a full weight 99 SS leather int and all. The only reason it was put on a dyno before the work that I did was to prove the gain I would get bc I had a couple ppl telling me it wouldn't pick up more than 10hp going from the ls6 intake and 1 3/4 headers. I'm not really all that concerned abt the number, just curious with the higher number considering the mods
