Help with oil pump/timing chain 5.3
I'm getting ready to install my new camshaft with Brian Tooley valve springs. They're 155lb@ 1.780 and 400lb@ 1.130. I'm stuck between spending the money for a SLP double roller timing chain set or taking the cheap way out and running a LS2 timing chain. Also, while doing the cam install I was going to replace the oil pump. Is GM part# 12586665 a good oil pump to run?
thanks for replying guys. at what point is the double roller a better idea? I could be way off here but I thought some people did not like the high volume oil pumps do to sucking the pan "dry"
A good single is better than a cheap double IMHO. Get a CR5 chain if you want a stronger one. I have the "regular" Melling oil pump. The SLP oil pump though is a good option.
thanks guys. running the melling pump and ls2 timing chain saved some money almost enough money to buy the valve spring tool over running a oem pump and a double roller cant be upset about that
Moderator
I center the pump every time. You can use feeler gauges or even strips of paper in a pinch.
You should disassemble the pump and clean it anyways, so while you have it apart, slide the housing on and center it with three feeler gauges. Hold it in position, tighten the bolts, and the feeler gauges should all slide out without much effort. This is why I actually like to use paper because if it takes so much effort to pull out that any of the paper strips rip, its not centered. Once you have it centered and bolts are torqued, use a good assembly lube to grease up the lobes and assemble the pump on the engine.
I've done this on every single pump install, with the engine in and out of the car.
I couldn't align the pump because I couldn't get the cover bolts out. If I tried any harder it felt like I was gunna break one. I emailed Melling and they said their pumps don't need aligned..so I hope it's alright.
