Rear main seal install victor reinz
Old 10-03-2014, 05:32 PM
VandykeT/A's Avatar
Default Rear main seal install victor reinz
Only thing left on my 408 is to install my rear main plate and it's ready to drop in. I've searched and searched but I just wanted to ask for clarity. The seal I have is a victor reinz it's all ready in the plate and it has the white plastic piece in the middle. At this point all I need to do is clean the crank apply NO oil to anything and simply bolt the cover on with some silicone at the corners? Or is there a trick to the plastic piece or is it just there to protect the seal. I also have the seal in the plate correctly it says this side out. Anybody have anything I should know before I put it together? Thanks
Old 10-03-2014, 07:24 PM
brads99xtreme's Avatar
I would think protection and installation.
Old 10-03-2014, 07:26 PM
S10xGN's Avatar
Here's my install, it was a National but also came with the plastic plate. First pic is the seal on my generic install tool, a 4" x 3" sewer reducer. Second pic is the stock (greenish) seal before pulling and last is the new seal in place. IIRC, the instructions said NOT to use any lube so I didn't and it's still holding just fine...
Attached Thumbnails Rear main seal install victor reinz-100_1034s.jpg   Rear main seal install victor reinz-100_1036s.jpg   Rear main seal install victor reinz-100_1041s.jpg
Old 10-04-2014, 12:14 AM
gMAG's Avatar
The white inner ring keeps the shape of the seal & also keeps the ribs from being misshapen.
I bought the factory GM version, which came with a light grease already on the inner edge of the seal.
Quick Reply: Rear main seal install victor reinz
