Gold colored dust in oil after heads and cam install
Old 10-15-2014, 01:38 AM
dannysauter's Avatar
Default Gold colored dust in oil after heads and cam install
So I just finished up a ls6 heads and cam install on my vette and have driven it for about 1500 miles. When I changed the oil i noticed a substantial amount of gold colored "dust" in the oil. There are no chunks or large metal particles that I can see. The car runs great with no abnormal noises and the oil pressure is good as well. Is this something that I should be concerned about or should I just change the oil and keep an eye on it?
Old 10-15-2014, 01:45 AM
Jontall's Avatar
It has to be main or connecting rod bearing material. You can have the oil tested to confirm or if it was me, drop the oil pan and start checking. This is something you should have done when you first noticed the gold dust, and yes, you should be very concerned.
Old 10-15-2014, 06:50 AM
RockinWs6's Avatar
Could be a lot of things, what did lube did you use on the cam when you installed it?
Old 10-15-2014, 08:14 AM
vettenuts's Avatar
If it is the bearings, it is likely an issue that requires major work. If it were my car, I think I would run it another 1000 miles then dump the oil again and see if you are still seeing the material. Also, if you still have the filter from the prior change then cut it open and check the material. Photos would help as well.
Old 10-15-2014, 06:28 PM
Old Geezer's Avatar
Lightbulb Cheap info..
http://www.amsoil.com/shop/by-produc...ysis-services/
Old 10-15-2014, 07:59 PM
gMAG's Avatar
Most likely, this is cam bearing material.
Have you held a magnet to the material to verify otherwise?
As long as you have good pressure and no abnormal changes, I would also change the oil & filter, and run it some, then re-inspect. At the slightest evidence of contaminants, you'll have to go further.
Old 10-16-2014, 10:11 AM
98cherrySS's Avatar
Before you tear apart the engine looking for bad bearings... Did you copper spray the head gaskets? According to a well known LSX shop/sponsor, it's pretty common to find gold dust in the oil when copper spray is used. It usually sticks around for a few thousand miles.
Old 01-24-2016, 02:10 PM
Jarren_b's Avatar
Hate to bump an old thread but did you ever find out what was causing the copper?
I used several coats of copper spray on my gaskets and noticed little specs that have my concerned now.
Here is my thread-
https://ls1tech.com/forums/generatio...-cam-swap.html
Quick Reply: Gold colored dust in oil after heads and cam install
