best heads to buy or should I port and polish.my stock ones???
My 2001 ws6 has 241 heads on it now the car has 21k miles they have never been ported my question is woukd it be worth my time to have my stock 241s gone thru or should I buy a set of 243s and have them ported? Will all my exsisting parts interchangeable between the two heads?? Or should I buy a set of trick flows?
I'd either have your stock heads ported or buy some aftermarket castings. By the time you buy a good set of 243's and have them ported you'll be over 3/4's of the way to the cost of some Trickflow 220 or PRC 225 as cast heads.
Everything is the same ancillary parts-wise. Push rod length should be checked regardless as head milling (which I would consider a great improvement), gasket thickness, cam, etc can change it. Easy to do with a $20 Comp push rod checker.
Here you go OP. AI can take care of you and make your stock 241's shine.
http://www.advancedinduction.com/LSX...RGMLS1Head.php
AI does good work. Something about seeing stock castings CNC'd is really awesome. I went with a cam motion cam for my setup and it drives beautifully. Specs in my sig.
Yeah I don't know how I came to that conclusion lol. Not such a good deal now . I'd just as soon buy some ported 243s and sell my factory heads to minimize downtime and not worry about shipping to and from.
