Need to refresh my stock LS1, what all is needed for what I want?
Right now, I have 127,XXX miles on my stock LS1 with an MS3 cam, PRC stage 2.5 5.3L heads, and a Fast 90mm intake. It has had a good life, and is still running, but is burning a little oil, and I want to rebuild the engine.
What all would be required to rebuild it like new again? I would like to install a MONSTER sized cam, and would love to touch closer to the 500 RWHP mark N/A.
Would I be better off going with a crate motor? If so, what are my options?
I want to stay somewhat cheap, but will do what is required to refresh everything so it is young and healthy again, and really want a larger cam than my already "large-ish" MS3 cam.
Options?
Options?
Have you done a leak down test? Do you have a catch can? Maybe you only have a problem with your PCV system and your motor is fine. I know this doesn't help you fit a bigger cam but it's just a thought.
I basically have your exact combo and put it in a 6.0 after my LS1 blew. It now has more compression plus more hp and tq. If you really want to break the 500 rwhp mark you should just get a 408 or something similar with better heads, cam and intake...that will do it
My LS1 with the same heads as you have, a medium cam (228R) and LS6 intake only made 400 RWHP. If you want 500+RWHP I fear a block that you can get over 400 cubes out of, better heads and a slightly bigger cam is in your future.
I am not sure what the CR is currently at. The 5.3L heads did bring it up a bit, so I am guessing my CR is not going to be able to come up much further. I would be happy with whatever a bigger cam would give on the rebuild.
Ok you're now saying you'd be happy with whatever power a bigger cam would give you, but before you said you'd like to get around 500 rwhp...you do realize that's not going to happen with just a bigger cam right lol? Also running a bigger cam with those heads on a stock cubes LS1 would not be a wise choice and in reality would not be any faster
Moderator
Options?
Options?
Your going to need a really good head to hit 500whp.
Something like a AFR 210 or TEA Trickflow 215 and a Hellion or Vindicator cam. Compression is going to need to be 11:8-12:1. A Fast 92 should work, also the exhaust will need to be free of any restriction. Some 1 7/8 headers and TSP or Kooks TD's. Valvetrain will also need to be light as possible.
So in a nut shell 500whp out of a 346 will not be cheap. Look up Patrick Gurerra"s "recipe for 500whp" thread.
