milled heads with stock pushrods?
Old 05-26-2004, 08:54 AM
TK 14 SS's Avatar
Default milled heads with stock length pushrods?
Just wondering, I now (finally) have the motor back together with all of the work done to include the heads have been milled .030.
My question is... I put the motor back together with the hardened (Thunder racing) 7.4" (Stock length) pushrods that I had in there before and was wondering, Is this going to be okay?
Thanks!
Troy
Old 05-26-2004, 12:06 PM
onyxxtreme's Avatar
it'll be okay till they all bend apun startup
Old 05-26-2004, 12:27 PM
1madss's Avatar
Use .030 shims under the rockers and you will be okay. This will make up for having the heads milled.
Old 05-26-2004, 12:43 PM
killer01ws6's Avatar
It depends on the base circle of your new cam, most aftermarket cams have a smaller BS and the milling will make the stockers come back to be about right.
Old 05-26-2004, 12:56 PM
TK 14 SS's Avatar
Allright, thanks guys. I put in a new custom grind Comp cam (from Combination Motorsports) so thinking (hoping) that it will be okay.
But I have to admit, I obviously addressed this possible issue a little late, didn't I ?
Onyxxtreme - you made my heart skip a beat at first
Old 05-26-2004, 01:03 PM
Scalpel's Avatar
All the Comp Cam LS1 grinds I have measured had a 0.030" smaller basecircle. If you milled your heads 0.030" then stock length will be ideal.
Old 05-26-2004, 01:32 PM
TK 14 SS's Avatar
Awesome!!!
Thanks for the info
Troy
Old 05-26-2004, 02:41 PM
1madss's Avatar
Hmmm. I' running a MTI C1 which is a Comp XE lobe and S2 heads milled .030, 7.400" pushrods and .030 shims under the rockers.
Old 05-26-2004, 03:23 PM
You may been putting too much load on the lifters, did you find out what the base circle of the cam was, that is a big factor.
Old 05-27-2004, 10:30 AM
1madss's Avatar
If the base circle of the cam was smaller than stock and I shimmed the rockers, that would cause me to run too little preload.
Old 05-27-2004, 10:46 AM
You are correct..
I was in a hurry, My bad.
