Valve spring break-in
Old 05-26-2004, 05:39 PM
brians98ss's Avatar
Question Valve spring break-in
Hey guys,
Just got a quick question concerning valve spring break-in.
I know that with aftermarket valve springs the motor needs to be at least warm prior to taking it to high RPMs. I understand the whole concept of aftermarket springs being a lot less forgiving than OEM springs when cold.
My question is what do you guys use as an indication of when your motor is warm? Do you wait for a specific coolant temperature to be reached? I have heard some people say that once the coolant temp needle is off the low peg that this is an indication of a warm engine.
Do some of you go by a certain oil pressure at idle?
Thanks,
Brian
Old 05-26-2004, 05:42 PM
jrp
SN95 Director
jrp's Avatar
normal operating temperature for me.
Old 05-26-2004, 05:43 PM
mike c.'s Avatar
i don't move my car ti'll the motor reaches full temp. then i know i'm safe.
Old 05-26-2004, 05:50 PM
Dustin 98TA's Avatar
I wait until it gets to normal operating temp.
Old 05-26-2004, 08:02 PM
marc_w's Avatar
Normal temp would take about 30 minutes of warmup in the winter here... (a few days last winter here were as cold as -10F)
Is that a good reason for me to look for a lower lift cam?
As it is (stock), I wait for the needle to get a few ticks off of the cold-peg before I drive.
Old 05-26-2004, 08:21 PM
marc_w's Avatar
Sorry - I forgot we were talking about break-in temps... not DRIVING temps.
Old 05-26-2004, 08:59 PM
LS1TECH Sponsor
foff667's Avatar
i start the car then just idle/drive it till the needle is off 160 to take it over 2000rpms, at that point the oil temp should be high enough that everything is safe.
Old 05-26-2004, 09:07 PM
JoeyGC5's Avatar
I'm ****.
The Vettes got an oil temp gauge, It doesn't move till the oils at 160 degrees, water temps usually about 180 by that point.
Old 05-26-2004, 09:09 PM
LS1TECH Sponsor
foff667's Avatar
Originally Posted by JoeyGC5
I'm ****.
unfortunatly ive got a 160 tstat so unless its 90 outside and ive been driving in traffic for 30 minutes it wouldnt hit 180
Old 05-27-2004, 08:44 AM
killer01ws6's Avatar
I'm ****.
Yep the oil takes longer than the water to warm up, just keep that in mind.
