Need Help Look at my Spark Plugs
Ok sorry about the bad resolution pics. This was one of the plugs u can see the pic attached. It looked red and right now my car is in the heat in the Middle East its very hot out. I have been getting alot of detonation so I think thats why its red ? correct me if im wrong. Before I get into details, its a 2002 WS6 M6 tuned by ls1speed with patriot performance ls6 style heads ( its burning oil I still did not install the newer seals Terry is using but I will right now. Also a g5x2. some other plugs were black and oily and i think thats from the valve seal leaking issue. Also idling has been acting up lately, it wont idle, it would just go down and shut off the motor even after its warm.
While driving the other day I felt like the motor was dying as some points its like one of the cylinders is loosing compression and then it runs fine and again when its the turn for that cylinder it happens again(just felt like that) and also like something banging at that same point of lost compression
so i pulled out the valve covers to see if theres anything out of the normal but all looked fine. so i decided on a compression test (or maybe gonna do the leakdown like everyone here suggests.)
Anything you guys suggest i should do and any comments on the spark plugs?
Thanks in advance.
Mahmood
EDIT: also, going back to a stock cam, would it be a problem if i still used the patriot double springs on the stock ls1 cam or should i get some stock springs and use those??
Thanks in advance.
Mahmood
Thanks in advance.
Mahmood
Thanks in advance.
Mahmood
coolant level is still the same, still in the Full section and not moved since the heads and cam install. and no foam. im still leaning towards the detonation that made it turn red. we have very bad fuel here, maybe 85 or 87, and its very hot. maybe thats what got it this red?
My truck is runing 10.3:1 comp, and if i get bad or low grade gas it pings alot and runs crapy. My plugs have looked a little redish brown before, but it all cleared up with some good stout additive. Try some good additive and drive it around to see if it helps any with the stalling and poor performance. Best thing is if you can fill a tank with 100 octane from a small air port. Its only $2.50 a gallon, and these days its the same or cheaper than premium.
Mahmood--
If you haven't already...get a 160* thermostat in that thing pronto. The high heat combined with crap gas is gonna make you detonate like mad. Is 87 the highest octane you can get over there? I'd also suggest running a colder plug while over there...maybe some NGK TR6's.
-Jason (Purdue Alumni )
Most of the shop books have a diagram in the back to help you read your plugs. I can't see crud in those pics, but you look like you are running lean. Look for little silver specs on the plug, particularly on the ceramic. That means detonation.
no small airports here, general aviation is not even allowed over here so only thing is commercial planes and those use jet fuel so thats out of the question.
a friend of mine mentioned toulene(sp) and xylene(sp), some additive they use for paint and supposedly it has 114 and 117 octane rating. he says he used it on his 383 stroker and it worked just fine. any suggestions ?
I have heard of people running those, but I have never tried them myself.
YOU do need better than 87 on a H/C car, and I am sure the PCM has you running on the lower octane timing table, which will also kill your performance.
Originally Posted by FinalTA
Mahmood--
btw jason, i graduated december 2003, when did u graduate ?
