Lq4 cam mix match
Old 12-16-2014, 05:47 PM
WEIGHTMAN's Avatar
Default Lq4 cam mix match
i current have a 2002 lq4 and a used ls2 camwith no rear reluctor wheel is there a kit available to convert from rear cam sensor to front or does come one have a parts list
i figuring a ls2 timing cover and a 3 bolt 1x cam gear set but what cam sensor is ok to use thanks
Old 12-17-2014, 03:35 PM
WEIGHTMAN's Avatar
help ttt
Old 12-17-2014, 04:00 PM
tfi racing's Avatar
Buy a used front cover with the sensor and connector extension,move your existing cam sensor wires to the front,change your cam sprocket,I did it on a 5.3,no big deal once you gather the pieces.
Old 12-17-2014, 09:00 PM
WEIGHTMAN's Avatar
what year and model of vehicle should i try
thanks
Quick Reply: Lq4 cam mix match
