Dropped head bolt down an empty lifter hole like a fool
Heads are back from the machine shop and all the hardware to boot from Texas Speed just showed up so what do I do... I dropped a small head bolt down my lifter hole while I was cleaning out the holes. I walked away from it for a day just to cool down.
I heard it land right on the damn windage tray. Tomorrow I'm gonna pull the oil pump and try to get a magnet pen maneuvered over to it. If that doesn't work I'm gonna try to use a slim coat hanger and try to drag it down to the oil pan and maybe snag it from there. If I get it down to the bottom of the oil pan I've read some forums where people have just left it on the bottom of the pan with no problems. Any votes?
Lifting the motor to pull the pan is gonna set me back big time and I'm trying to avoid that at all costs. No name calling necessary, not the stupidest thing I've ever done but pretty fn close.
If you can't get it out the front, is it small enough to move toward the oil pan drain plug? You might be able to use a strong magnet (magnet on outside of pan) to drag it to the drain hole.
I'm def gonna try the valley cover option and the front cover option. Appreciate all the replies! Once I get in there I'll let ya'll know how things turned out.
Don't feel bad, I was helping a friend put a new topend on his motor and he dropped a washer in the intake while installing the carb. Pulled the intake and no washer, Pulled both heads and still no washer. I suggested we roll the car back and look under the car and he reluctantly agreed while swearing the washer fell in the intake. Rolled the car back and there is was lol.
