Tq specs Quick ref.
Tq specs Quick ref.
Here's a quick reference list. Copy, paste, save, ignore, whatever. I'm having a slow day at work.
All specs are lbs-ft unless noted otherwise. ***These are when using GM OEM Fasteners***
A/C Belt Tensioner Bolt
18
Accelerator Control Cable Bracket Bolts
89 lb-in
Camshaft Position (CMP) Sensor Bolt
18
Camshaft Retainer Bolt
18
Camshaft Sprocket Bolt
26
Clutch Pressure Plate Bolt (In Sequence and Evenly Over 3 Increments)
52
__________________________________________________ ___________________
Connecting Rod Bolts – First Pass
15 (Step 1)
Connecting Rod Bolts – Final Pass
85 degrees (Step 2)
Crankshaft Balancer Bolt – Installation Pass with Used Bolt – to Ensure the Balancer is Completely Installed
240
Crankshaft Balancer Bolt – New Bolt
•Step 1
110
•Step 2
Loosen 360 degrees
•Step 3
59
•Final Step
125 degrees
__________________________________________________ ______________________
Crankshaft Bearing Cap Bolts – Inner Bolts – First Pass in Sequence
15 (step 1)
Crankshaft Bearing Cap Bolts – Inner Bolts – Final Pass in Sequence
80 degrees (Step 2)
Crankshaft Bearing Cap Side Bolts
18
Crankshaft Bearing Cap Studs – Outer Studs – First Pass in Sequence
15 (Step 1)
Crankshaft Bearing Cap Studs - Outer Studs – Final Pass in Sequence
51 degrees (Step 2)
__________________________________________________ _______________________
Crankshaft Oil Deflector Nut
18
Crankshaft Position (CKP) Sensor Bolt
18
__________________________________________________ ________________________
(Early models)
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
22 (Step 1)
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
90 degrees (Step 2 -All Bolts)
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
90 degrees (Step 3-long bolts)
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees (Step 3-Med bolts)
Cylinder Head Bolts (M8 Inner Bolts in Sequence)
22
(Late models)
Cylinder Head M8 Bolts – in Sequence
22
Cylinder Head M11 Bolts – First Pass in Sequence
22
Cylinder Head M11 Bolts – Second Pass in Sequence
90 degrees
Cylinder Head M11 Bolts – Final Pass in Sequence
70 degrees
__________________________________________________ __________________________
Drive Belt Idler Pulley Bolt
37
Drive Belt Tensioner Bolt
37
Engine Block Coolant Drain Plugs
44
Engine Coolant Air Bleed Pipe Bolts and Studs
106 lb-in
Engine Flywheel Bolt (First Pass)
15 (Step 1)
Engine Flywheel Bolt (Second Pass)
37 (Step 2)
Engine Flywheel Bolt (Final Pass)
74 (Step 3)
Engine Front Cover Bolts
18
Engine Rear Cover Bolts
22
Engine Valley Cover Bolt
18
Exhaust Manifold Bolts – First Pass
11 (Step 1)
Exhaust Manifold Bolts – Final Pass
18 (Step 2)
Fuel Injection Fuel Rail Bolts
89 lb-in
Intake Manifold Bolts (First Pass in Sequence)
44 lb-in
Intake Manifold Bolts (Final Pass in Sequence)
89 lb-in
Oil Pan M6 Bolts – Oil Pan-to-Rear Housing
106 lb-in
Oil Pan M8 Bolts – Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
18
Oil Pan Skid Plate Bolt
15
Oil Pump-to-Engine Block Bolts
18
Oil Pump Cover Bolts
106 lb-in
Oil Pump Relief Valve Plug
106 lb-in
Oil Pump Screen Nuts
18
Oil Pump Screen-to-Oil Pump Bolt
106 lb-in
Spark Plug (All Subsequent Installations)
11
Spark Plug (New Cylinder Head)
15
Throttle Body Bolts
106 lb-in
Torque Converter Bolt – 4L60-E/4L65-E Transmissions
47
Torque Converter Bolt – 4L80-E/4L85-E Transmissions
44
Transmission Bolt (Automatic Transmission)
70
Transmission Bolt (Manual Transmission)
37
Transmission Cover Bolt
106 lb-in
Valve Lifter Guide Bolt
106 lb-in
Valve Rocker Arm Bolt
22
Valve Rocker Arm Cover Bolt
106 lb-in
Water Inlet Housing Bolts
11
Water Pump Bolts – First Pass
11 (Step 1)
Water Pump Bolts – Final Pass
22 (Step 2)
Water Pump Cover Bolts
11
18
89 lb-in
18
18
26
52
15 (Step 1)
85 degrees (Step 2)
240
•Step 1
110
•Step 2
Loosen 360 degrees
•Step 3
59
•Final Step
125 degrees
15 (step 1)
80 degrees (Step 2)
18
15 (Step 1)
51 degrees (Step 2)
18
18
(Early models)
22 (Step 1)
22
(Late models)
22
22
90 degrees
70 degrees
37
37
44
106 lb-in
15 (Step 1)
37 (Step 2)
74 (Step 3)
18
22
18
11 (Step 1)
18 (Step 2)
89 lb-in
44 lb-in
89 lb-in
106 lb-in
18
15
18
106 lb-in
106 lb-in
18
106 lb-in
11
15
Throttle Body Bolts
106 lb-in
47
44
70
37
106 lb-in
106 lb-in
22
106 lb-in
11
11 (Step 1)
22 (Step 2)
11
