putting a ls1 into a tbss
im looking into getting a tbss with a blown motor. i have a 383 ls from my camaro that i have just sitting around. what would it take to put that in the tbss? i know the cam sensor needs an extension but will the pcm harness etc from the tbss work? anything else i would have to do?
That's MISTER MODERATOR
The vehicle is 58x. You'll need to swap the crank to a 58x and the cam gear to 4x and the front cover to accept the front cam sensor. Plus the above mentioned block side knock sensors.
Chat with Glen at B&B: http://bbautomachine.com/
The vehicle is 58x. You'll need to swap the crank to a 58x and the cam gear to 4x and the front cover to accept the front cam sensor. Plus the above mentioned block side knock sensors. Chat with Glen at B&B: http://bbautomachine.com/
