LS1 lifter preload
Old 02-10-2015, 01:14 PM
Jarren_b's Avatar
Default LS1 lifter preload
I know there are multiple threads on this but im having a hard time finding a definite answer.
I have a BTR stage 2 NA cam. specs are 227/234 .614"/.576" 113+2
When I first installed it my valvetrain noise was insane with 7.400 pushrods
I got rid of those and went to 7.425 and it made it much quieter. I still have valvetrain noise especially under light load from 1000-2000 rpm. I have longtubes so it makes it worse
Basically im questioning if my 7.425 pushrods are also too short. I bought a pushrod length checker that ill be using in a few days so I have a few questions
Do 97 Ls1's have a thicker head gasket?
Will I need two different length pushrods from the difference from my intake and exhaust lift?
what is the best preload for stock LS1 lifters?
Does the trunion upgrade help with noise?
Thanks in advance for the help
If Brian tooley racing wanted to chime in that would be great!
Old 02-10-2015, 01:30 PM
Jarren_b's Avatar
Or how could I find out Pushrod length with the base circle measurement of the cam?
Unfortunately I dont know the base circle size
Old 02-10-2015, 03:25 PM
Jarren_b's Avatar
Based on my research it seems that this formula is correct. someone let me know if not.
So stock Ls1 cam is
39.37/2=19368 mm or (.775")
My cam is 35.8902/2=17.945mm or (.706")
.775-.706 is .069 smaller
So to stay within stock preload settings I would need atleast a 7.450 pushrod or higher? Technically 7.465?
Currently I have 7.425. Which would explain the noise.
Old 02-11-2015, 12:59 PM
BlwnLs1GTO's Avatar
I have 8 brand new Comp Magnum PR's in a 7.450. .080" wall that I cant use for my build. 35 bucks shipped if you want them. LMK.
Sorry I'm not adding any tech info, but this was a perfect time to help you and me out.
Old 02-11-2015, 01:32 PM
svede1212's Avatar
Measure. Don't calculate or guess or go by sound. You want .050-.060
Old 02-11-2015, 01:40 PM
WE TODD DID's Avatar
You ask ten people, you'll get ten different answers. I run mine .010"-.015" from bottomed out. In my findings, the engine makes more power and runs faster.
Old 02-11-2015, 02:11 PM
Jarren_b's Avatar
Dang I wish I would have seen these earlier. I just bought some locally last night for 130!
Old 02-11-2015, 02:12 PM
Jarren_b's Avatar
I measured also last night when I installe and 7.450 came out to be perfect size for me. My Valvetrain sounds much better now and the car feels stronger. could just be all in my head I guess lol.. Turns out the math method and measuring were completely accurate in my case.
Quick Reply: LS1 lifter preload
