Spun rod bearing- bottom end ???'s
Old 05-31-2004, 04:47 PM
etperformance's Avatar
Default Spun rod bearing- bottom end ???'s
As the title says. Looking for info on good bottom end components on the 346, with stock crank if possible. Currently running mid 6's on a 125 wet shot. What do you reccomend to be able to run a 200-250 shot on a NX dual stage MAF kit. Can this hold? I am trying to stay semi budget minded as possible. I know I can but the most expensive **** out there, but I am looking for advise on proven components. Thanks
Old 05-31-2004, 04:56 PM
Josh's Avatar
Sorry to hear about your misfortune. I'm not educated enough to advise you on component selection, but if you don't mind my asking, what caused the bearing to spin, do you know yet?
Josh
Old 05-31-2004, 05:00 PM
AZ Power & Sound's Avatar
I have a stock crank and 7 pistins/rods with less than 10K on them... all mint condition if you are interested. All parts from a 2002 LS1 engine. Bearings were all mint but the head dropped a valve seat and destroyed the piston and block... I salvaged the rest though. Make offer!
Old 05-31-2004, 05:14 PM
Josh
I don't know why, but I am think bypassing the window switch didnt help. After I bypassed it, the problem happened. Still ran a 6.5 though.
Old 05-31-2004, 05:15 PM
Thanks, but I am looking for a forged bottom end.
Old 05-31-2004, 06:44 PM
jrp
SN95 Director
jrp's Avatar
hit up APE or HPE
Old 06-01-2004, 12:43 PM
Anyone?
Old 06-01-2004, 01:34 PM
2001CamaroGuy's Avatar
Forged rods and pistons would be good, but I personally don't think a forged crank is needed. The stock one seems to just keep taking more and more HP/RPM and never comes apart.
Old 06-01-2004, 01:49 PM
TK 14 SS's Avatar
Well, I t spun a rod bearing and went through much of this but without the foged parts. Yes, they do say that the stock crnmk is pretty good but I can tell you that ,ine endede up being bent over .100"
So, the way that I see it is if you're gonna get forged pistons and rods than why not do the forged crank also, especially if you're going to hit it with the big juice. It's better to do it now than have to redo it later...
Troy
Just my "still learning" $.02
Old 06-01-2004, 02:47 PM
Troy
your point of "do it right now or do it right later " is valid , but the spun rod bearing had nothing to do with the crank (that was a rod bolt failure) and I have yet to see ANYTHING on broken cranks (even offset ground cranks) so I just think the extra $700 for the forged unit (I got a brand new crank for $350) is money that could go to something else.
it all comes down to what helps you sleep at night (ex: I first ordered Comp Pro-mags and for a month worried "did I mess up...should I have baught shaft mount?" and it was driving me nuts ....finally I couldn't take it any longer and had to eat the extra $500 so I could sleep)
Old 06-01-2004, 02:51 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
I'd build a 10:1 or 11:1 flattop piston shortblock.
You are not per se looking to make more power n/a just to have stronger pistons.
I am running a stock crank.
Old 06-01-2004, 02:56 PM
Specific suggestions on parts/ source?
Old 06-01-2004, 04:06 PM
TK 14 SS's Avatar
Damn that's some pretty messy stuff I wrote, I really hate that computer (at work). What I said, in a nutshell was that I "spun a bearing" and that "my cracnk was bent over .100"
But I see your points and John's too! Hey, I redid mine on a new stock crank and stuff so I must not distrust them that much huh?
Troy
Old 06-01-2004, 04:36 PM
LS1Tech Co-Founder
I'd look into off the shelf pistons, maybe Diamond, with valve reliefs... and some 6.125 H or I beam rods, ARP L19 rod bolts, probably ARP head studs.
Old 06-01-2004, 05:12 PM
mitchntx's Avatar
Not sure where in Texas you are located, but I am currently having a stock bore forged pistons, stock rods/crank, de-burred, coated, fully blue-printed and balanced for under $2K which includes bearings, pistons, rings ...
The guy builds T2 motors for SCCA and is located in Ft. Worth ...
