Car has to much crank pressure why?
What would cause excessive crank pressure? Pcv is perfect and if I leave the oil cover off it helps still lots of pressure and I also have a catch can. Any help will be nice?
Ive deleted pcv idle goes high. Ive routed pcv multiple ways the crank case pressure does not change. Removed the oil cap with and idle shoots up to 3000 tuned it with oil cap off. Is asking for stupid numbers to run even at 16.0 afr in the ve table. With oil cap off oil pressure is fine with it on, its extremely low until wot. Afr with oil cap on or off while regular crusing is fine until the car is shut off, then once started again idles rich around 11.5 afr then when driving is fine around 15.7 afr until about 3min in then its about 18-20 afr extremely lean but all wot is dead on at 12.8. ive checked for vacuum leaks already the old school way with the starting fluid but nothing was found. Only place I cant check is under the intake. Have not done a compression test. Ls1 style pcv, set up is damn near stock so it should work fine.
