MMS 220 heads....Info, Pics, and discussion inside
#202
10whp over a FAST isn't much? Seriously? Companies have been trying to outdo the FAST intake for over a decade and pretty much everyone of them have failed. What do you think is going to happen when the MSD gets ported considering it's already 10whp better than a FAST?
If you think 10whp isn't much, how would you feel about a Mamofied FAST being only 10whp better than an unported MSD?
#203
Is anyone close to having numbers? I'm still torn on my choice of heads for my forged LS6 and want to justify the extra cost over having my 243's CNC'd. Hoping for something upward of 500 reliably with a 102, 1 7/8 LT's, and not totally outrageous bumpstick.
#204
Moderator
Received 1,836 Likes
If things go really well, I will in a few weeks.
#205
Just waiting on the headers
Heads, Cam, Ported FAST 92 Intake and Ported LS2 Throttle Body all from Tony Mamo are installed. Just waiting on the headers from Maryland Speed, which they say were sent to be ceramic coated today. We'll see! And a few pics to show the progress.
#206
What kind of combo are you going with? Something a little wild or mild?
I bit the bullet after talking to Tony for 20 minutes and am now going with a very stout build myself. His passion for this stuff was clearly noticeable over the phone and admitably quite contagious. I sent my 102 to him priority mail today in hopes he'll be able to get to it that much sooner. I hope you see that Tony! I'm very excited to get everything together and see what the combination is capable of. I am hoping to have everything at my engine builders by the end of August and will start my build thread once things are concrete shortly.
Cheers guys and keep the posts coming.
#207
Moderator
I've got a build thread going
#208
Will the frustration ever end?
UPS delivered the X-Pipe and header parts late yesterday afternoon. Box was in good shape and the pipes are pristine, however, the O2 sensor extensions for the 04 Corvette are missing. The parts inventory listing from LG Motorsports show that 2 pairs of square to square O2 extensions ('04 only') should have been in the box. I've carefully gone through the packaging from the box and they are not present. I've contacted LG Motorsports and they are going to ship them out on Monday which is wonderful service, but I've been set back another week. None of this will make any difference in ten years - but for now, I'm pretty frustrated. Thanks for listening!
#209
Moderator
totally feel your frustration there. My car would be running except for the crossover kit I ordered two weeks ago from jegs is still not here.
You know, you'd think heads, intake manifold, custom pushrods, etc might take longer than an off the shelf part, but NOOOOOOO.......
#211
#212
Moderator
#213
Headers are on - car won't start
I got all of the parts and have the headers installed. Everything is buttoned up but it won't start. I'm getting a No Comm. error for all systems in the DIC. The engine cranks normally but there is no indication the it's firing.
I disconnected both engine grounds on the lower portion of the block prior to installing the headers to ensure none of the wiring would get damaged and reinstalled both grounds before tightening the headers down. I've checked both those grounds and I don't think they are the problem.
Fuses 16 and 23 in the Under Hood Fuse Box are good. The mini relay #42 - IGN is making a humming sound that's not normal.
I have not run the engine since installing the FAST 92, LS2 Throttle Body and headers.
I'm stumped!
I'm stumped!
#214
I'm stumped!
I'm stumped!
GL
#217
Took the car for a five mile drive, never got on it and never drove over 50. Just wanted to make sure it would get me to the tuner. Car sounds great and feels punchier for the short time I had it out. The earliest I could get in was Monday, Aug. 24th. I'll keep you guys informed about how it goes at the tuner.
#218
LS1Tech Sponsor
Should be a whole new world when you finally get everything calibrated properly. Your tuner should be able to get all the injector info for those FAST Bosch 36 lb injectors online fairly quickly if he Googles. Or even on this board in the tuning section etc.
Another week and change we have to wait!!
Oh well....LOL
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
#219
Still has the OEM injectors in it. I won't change them out until I'm at the tuner's on the day of the tune. Parking the car now until the 24th. Can't wait to have a car the I can drive again.
