LQ4 lifter carnage. Need guidance.
Old 03-27-2015, 01:14 PM
bayer-z28's Avatar
Default LQ4 lifter carnage. Need guidance.
(2000 Silverado LQ4, 136k miles, Auto. Bought with lifter knock for CHEAP! )
Well the lifter knock mystery is solved. #2 cyl intake valve, so the second lifter in.
Just pulled it apart today. I had to use vice grips and a pry bar to get this sucker out. I scored the block a little but I'm hoping I can hone it out. It doesn't feel very deep.
The cam is a little scored as well so a new one is in order.
The lifter bore isn't scored that bad. The cam is more beat up. It's worse at the peak of the lobe. I don't want to chew up another lifter and end up doing this again in 6 months. I got the truck like this and it looks like the guy who fixed it last didn't use the right lifter and only replaced one. The oiling hole is different, and not in the same spot. The body is different. Did this spin? or did the roller bearing go? I don't see any casting numbers on it. cheap POS?
I still have the stock cam out of my 2000 Camaro, the firing order is the same and it "should" work, but I fear it'll lose low end and gain top end. I could get a TSP low lift 218 cam for it. Or is there something else that would work just as good for a SLIGHT bump for the cam. No MS4, no Torquer cam... just a very mild upgrade. Still completely stock otherwise. I'm pretty open minded on this. I think the TSP 218 cam was like .588 lift on a 114.
I have a 10295 Melling oil pump I'm going to replace with it. I'm pretty scared about where the crumbs ended up. I HOPE and pray they ended up on the bottom of the oil pan and the pickup screen did its job. I'm going to drop the oil pan and clean it out. I don't want to chew up a brand new oil pump.
With all the lifters out I "should" be able to blow the lifter valley and cam valley with a blow gun and rinse it with some oil and it "should" wash any remaining crumbs down to the oil pan right? and then I can pull the pan and clean everything out.
Anyway.. Here's the pics.
Old 03-27-2015, 03:37 PM
JRENIGAR's Avatar
Uhhh, Fuuukkk!!!
Old 03-27-2015, 03:44 PM
96capricemgr's Avatar
The LQ9cam was supposed to be the same as the late LS1 cam.......
Old 03-27-2015, 05:24 PM
bayer-z28's Avatar
I was wondering about that too. see if an LQ9 cam would be an upgrade... Hmmmm.
Old 03-27-2015, 05:43 PM
bayer-z28's Avatar
Anyone hear any good word about that TSP 218 Cam? Worth the money or not really? Or should I just stick the stock LS1 cam in there? Seems like it'd be a good bump in lift..
Vengeance has their VRX1 that looks tempting.. 220/220 .581/.581 114 LSA
Old 03-30-2015, 08:06 AM
Old Geezer's Avatar
Default Cut the
oil filter open. That will give you an idea as to how much crap went thru the system....
Old 03-30-2015, 06:10 PM
bayer-z28's Avatar
That's a good idea.. I'll do that.
Old 04-04-2015, 05:47 PM
bayer-z28's Avatar
This truck is filthy. Got the oil pan off this morning. Had to drop the front diff.
Shrapnel in the oil pan. The cam bearings looked pretty good. Still had a white-ish hue to them. Looked almost new actually. We have a fiber-optic scope with a color display and I snaked the cam bore.
Cleaned the pickup tube, Camaro cam installed, Melling pump installed (old one looked pretty beat up from what I could see but I haven't taken it apart yet), was ready to put the oil pan back up but I still have a couple things left to button up before I can do that.
Stock cam was pretty beat up. a nice divot on the uphill side of the cam. Camaro cam on the right with almost no miles on it. (30k, ish)
Truck is so filthy.
And... the shrapnel in the oil pan. I went fishing with a magnet.. lol GOnna cut the filter open.
Quick Reply: LQ4 lifter carnage. Need guidance.
