Question about Joe Gibbs oils
Old 03-27-2015, 05:15 PM
lovethyGM's Avatar
Default Question about Joe Gibbs oils
Anyone use Joe Gibbs ls30 or any Joe Gibbs oil....any how u like it.....
Old 03-27-2015, 05:50 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Fixed your title so it makes sense.
Old 03-27-2015, 06:27 PM
Rise of the Phoenix's Avatar
Yes, I run the Joe Gibbs LS30 oil in my WS6. Good stuff for sure. Lots's of engine builders swear by it and will only warranty the motor if it's used.
Old 03-27-2015, 09:04 PM
lovethyGM's Avatar
Thanks....
Old 03-27-2015, 09:15 PM
conan's Avatar
I ran Joe Gibbs break in oil for the first 300 mile and dyno tune of my 383ci. No complaints, motor ran nice and quiet.
Old 03-27-2015, 09:23 PM
Paul Bell's Avatar
Joe Gibbs oil is very good. Necessary if you're road racing the car and you spend a lot of time at high RPMs and go through high G turns.
Not necessary for an everyday driver that sees the occasional drag track or street drag race. Most upper shelf synthetic oil will exceed what an engine needs.
I've tried JG oil and didn't see any improvement in performance or oil life. I don't see the need to spend that much coin on it.
Today's modern roller cam engines really don't need a break in oil.
Old 03-28-2015, 12:20 AM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
New/Rebuilt Engines with Fresh Cylinder Bore/Hone & New Rings
Will Absolutely Benefit from a quality Break-In Oil with a Hgher
Zinc/Phosphorous (ZDDP) content for best Ring Seal! Regarding
Roller Rockers. Most on this site are running anywhere from a
Little more spring pressure to considerably more spring pressure.
Do a little research, the more you have invested in your engine
The more sense it makes not to cheap out on oil.
Old 03-28-2015, 12:29 AM
Paul Bell's Avatar
I doubt it.
Any quality non-synthetic works well as a break in oil. Too much zinc and you'll just prolong the time for the rings to set in.
Zinc in motor oils was only to reduce wear on flat tappet lifters. Roller lifters used today is only one reason it's not a lubricant package component anymore.
I used to get suckered by advertising and "what everybody says to use this week" but I'm better educated now.
Old 03-28-2015, 09:16 AM
lovethyGM's Avatar
Originally Posted by Paul Bell
I doubt it.
So Paul bell are u recommending that you use a non synthetic as opposed to synthetic......for a daily driver.....or are you just saying that for break in procedures.....
Old 03-28-2015, 09:38 AM
The break in oil is made for a reason and there is science behind it. Why not use it when you spend that much money on the motor setup. Same goes for hifh end oils lik Joe Gibbs. I'll gladly pay a little extra for it knowing I have a great oil that I don't have to worry about.
Old 03-28-2015, 09:46 AM
Paul Bell's Avatar
Only as a break in oil. Synthetic is too slick to use for break in.
Lubricants with high zinc is for tappet cams. You can use it but as a break in oil, there's zero advantage over using a good dino oil.
JG is a great oil. Use it if you want to and can afford it. Just keep in mind that it's not doing anything that other top shelf (and less expensive) oils do.
Old 03-28-2015, 02:07 PM
Gray86hatch's Avatar
I use it. Wear in the valve train is reduced using it. Gibbs would not have developed all the different lines of oil if different engines didnt have different requirements.
I have some ĉlose friends that work in the valvetrain industry and the new no zinc oils are causing issues.
Tim
Old 03-28-2015, 02:16 PM
My valvetrain is quieter using it too.
Old 03-28-2015, 03:19 PM
Zmg00camaross's Avatar
It's been proving that today's oils are not up to par with modern hot rod engines. Stock engines and such are fine with today's oil. But big cam and rpms you want something a little more. I run schaffers 5w40. Only reason for the 40 weight for me is I bracket race and test and tune and have a lot of passes in Missouri heat and just holds up better for me.
Old 03-28-2015, 03:28 PM
Paul Bell's Avatar
I love Schaffers. If it was locally and readily available off the shelf oil it'd be what I stock. I'll be sticking with German Castrol.
http://speedtalk.com/forum/viewtopic.php?f=1&t=31363
Old 03-28-2015, 03:31 PM
Car quest in my town is a dealer
Old 03-28-2015, 03:52 PM
Good to know. You remember what it is for a quart?
Old 03-28-2015, 04:24 PM
Think $7.55 or so.
Old 03-28-2015, 04:28 PM
They got 5w30 or 10w40?
Old 03-28-2015, 04:36 PM
Think I seen 5w40, 10w30. If they don't have it they can order it.
Quick Reply: Question about Joe Gibbs oils
