P/V clearance for this cam?
I have a set of Force Fed heads that are '99 5.7L castings, milled .030 for a bump in compression from 10.1:1 to 10:8:1. I am currently running the LPE GT2+3 cam and I'm seriously looking at the following cam:
TSP Custom 228R Cam: 228/228, .588"/.588", 112 LSA
What do you guys think about P/V clearance on this cam with these milled heads? I don't think it's going to be too much, but I would like your input. Thanks!
woah..that's a big cam!....hehehe Really man, that is a straight up grind and I don't see any trouble even with the milled heads. I'd be surprised if you were getting even close to hitting yet. we can always use my motor as a mockup before i put the heads on it and clay it. then we can compinsate for the mill. I have .007 milled on mine.
