upgrade opinions HPDE/time trial car
Building a HPDE/time trial car and am curious on a few items before I buy stuff.
Car is around 2600 pounds, getting an 04 GTO pullout with a T56, 110k miles.
Plan on the below
improved racing oil pan baffle
melling high flow/pressure oil pump
comp cams 11-428-54, 228/230 .571/.573. 112+4
Trunion kit
PSI 1512 springs
Comp cams 875-16 short travel roller lifters
new lifter guides, drilled
new pushrods, need to check for length
1 3/4 long tube headers
Coyles timing set
3qt accusump
Possibly new clutch and lightweight flywheel, open to recommendations on these as well but no carbon stuff since I can't afford it...
Leaving everything else stock, ls6 intake, 241 heads and bottom end. Rev limiter set to 6800, dyno tune.
This seem like a decent plan from a matching perspective? Any glaring issues?
Thanks
Plan on the below
Trunion kit
PSI 1512 springs
Coyles timing set
3qt accusump
Thanks
