5.3 cam selection
5.3 cam selection
After doing a few hours of research, I have come up with 3 cams to choose from.
The motor is a factory from pan to intake 5.3 with the 706 heads. it will be going in a fox body coupe setup for open track/street cruising, th350, irs rear with prolly 3.55 gears (factory gears in irs). I want to stick with a low lift cam for ease on valve train. Heres the 3 cams:
ASA 226/236 @.050 .525 lift 110 LSA
Texas Speed 228R 228/228 @.050, .588"/.588" Lift 112 LSA
Comp XR277HR 224/228 @.050, 534/537 Lift 112 LSA
Spring recommendation would also be great along with any other cam.
Thanks
Thanks
Moderator
Received 1,835 Likes
with stock 706 heads, I would go with your third option. comp 918 or PAC 918 springs ought to be enough to control the valves. The ls6 springs could handle the lift, but you might want higher pressures.
look into higher stall speed converters for that as well.
Thank you, I did check them out I found the valve springs cheaper there that I was looking for! I did check out their cams but nothing I was crazy over.
"I want to stick with a low lift cam for ease on valve train."
Fyi, low lift does NOT make a cam easy on the valve train, the cam lobes ramp rate does.
For example the TSP 228r cam in you selection has very aggressive Comp Cam XE-R cam lobes. That not what you want at all.
For your 5.3 and 2800-3k stall TC I'd go with the Comp XR277HR on your list, or something a little smaller like the XR275HR (222/224 112lsa+2, lift .566"/.568") or XR273HR (220/224 112lsa+2, .530"/.534") , all which use fairly mild cam lobes.
Two votes on the comp and I guess the 228r is out.
Super Hulk Smash
FlowTech Induction StreetSweeper-TQ 220/224 .597"/.592" 111 LSA or the FTI StreetSweeper-HT 228/232 .612"/.600" 111 LSA.
Run the BTR Platinums with it and you'll be fine.
Depending on what you want, either would be fine in the truck.
Cam Motion also has similar cams to the above FTI stuff.
The FTI is ground on Lunati cores and has custom lobes which are very stable and are easy on the valvetrain.
thanks Jake, ill check them out.
I just realized there are 2 ASA cams, GM and Howards. I run Howard retro roller lifters in my sbc 406. Like there products a lot and will have to lookup their ASA cam.
This is what im trying to find out on any cam im looking at. Trying to find middle ground and so far the comp 277 is the top contender. I liked the street sweeper tq but was pretty aggressive on the ramp rate from what im seeing.
Thanks everyone for the help. I am going with a Comp cam but not the 277. Its the xr275hr, little more lift but less duration. Also picking up the PAC 1218 springs.
