Q for AP chris and others
If you had a stock low mile strong running Ls1 and it was slightly ticky (lifter preload on the light side)Like alot of them. And you ordered a set of heads shaved .020 and a mild cam wouldnt you figure stock length pushrods would more than likely the what you would start with?Thanks
Under criminal investigation for fraud
Gonzo, most of our heads use the 7.350" length pushrods that is why I sent them to you. When you get them please check your preload, if they are not the correct length I will send you out the right length. Just let me know.
Thanks
Thanks
This is hard to believe,these guys have been totaly on top of customer service,inspite of how busy they are and there great prices for top of the line products. maybe its your aprouch or ????????Im sure they will respond
I also agree that there service is as good as I have seen in the country ,and I deal with a lot of companies. However I have left 6 messages in the past three weeks and I don't get them returned. Thought this thread would get him to call!
