Enough blow by to push ounces of oil out rear main?
2004 GTO...
Engine was shot due to Comp lifters failing from previous owner. I was going to rebuild it. Bought some 799 heads from a guy, and he just so happened to have a 2002 LS1 short block for sale that I bought, instead.
Long story short, people know this guy, and know he was running a supercharger with 0 supporting mods and most likely cracked some ring lands. Whatever...
Car runs and drives ok, makes good power. Cruises around just fine with normal oil consumption from a jacked up motor. Problem is at high RPM pulls, in say 3rd gear, car will start smoking like crazy! First I thought it was really bad blow by. Then I noticed that the smoke was coming from oil covering the headers under the car.
Did a test pull in third gear, up to 6,000 rpm. Pulled over and literally watched oil pour out of the bell housing. Ounces of oil, probably 6 ounces or so. And that doesn't include the oil that had already covered the under side of the car... again.
My thought is that blow by is so bad at high RPM, it is pushing oil out the rear main.
Other thought... Melling High flow high pressure pump. It will literally peg my oil pressure gauge out at over 100psi. That's a **** ton of pressure, yeah... But where would it be leaking from in the bell housing? Maybe by where the oil cooler ports would be plumbed? That's where I get my oil supply for the turbo on my other turbo LSX build, so I guess it's possible?
I have searched, and everything I find, is people talking about oil PUKING out of the bell housing, but then I read further, and their talking about a puddle like 3" in diameter. I'm talking about literally pouring a solid stream, and starting to run down the street, quantity.
Any thoughts guys?
Any thoughts guys?
Moderator
Several possibilities. Won't really know until you pull the trans and rear cover.
I've seen people hook up a PCV valve wrong and boost pressurized the crankcase causing similar problem.
If it's related to the oil pump, and it coming from failed rear cover seal, you should see the pressure fluctuate on the gauge.
Another thing is that I can be parked and rev the engine and hold it at like 5k rpms for about 4 or 5 seconds, and no oil pours out. So that tells me it may not be an oil pressure issue. I want to hold it at about 6k for around 6 seconds and see if it does it. Neighbors start looking at me weird the more I do that though... Lol
Oil pressure is too much, or crank case pressure is too much? Cause oil pressure wont push anything out of the seals(except maybe the pressure passages on the oil pan). It pushes out of the rods and mains, then simply falls to the oil pan. Only reason I brought up oil pressure, is cause maybe there is something behind the rear cover that I'm not thinking of, as was mentioned a few posts ago.
The rear main was a brand new one. But since it is a reverse lip design, crank case pressure may have blown it inside out?
I'm currently doing what I should have done in the first place, and am rebuilding the LS6 block that actually came out of the car, rather than trusting another shady person on craigslist. I just wanted to get some speculation on what you guys thought it could be. I do appreciate the replies.
