Sealant on rocker support bolts?
Old 06-16-2015, 11:16 PM
2002_Z28_Six_Speed's Avatar
Default Sealant on rocker support bolts?
Are you supposed to use a thread locker or sealant on the rocker support bolts? I think they might be a source of oil leaking into the intake ports.
If so what type did you use?
Old 06-16-2015, 11:52 PM
blk00ss's Avatar
Yes. Teflon thread sealant.
Old 06-17-2015, 12:49 AM
The Scammer Hammer
dr_whigham's Avatar
Of the port job on the head shows the threads for the rocker arm bolts, then YES. Otherwise stock, they're a blind hole.
I use either ARP thread sealant, or RTV Ultra Black, whichever I happen to have on hand at the time.
Old 06-17-2015, 01:12 PM
01ssreda4's Avatar
This is your correct answer.
Old 06-18-2015, 11:05 PM
I figured as much! I have ported heads so it looks like I need to do this. Thanks guys.
Old 06-18-2015, 11:25 PM
Burken01's Avatar
Yes, very common problem and an easy fix
Quick Reply: Sealant on rocker support bolts?
