I think I bought the dirtiest 6.0 in the country - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 07-20-2015, 11:30 AM   #21
BlwnLs1GTO's Avatar
I'd just take it down all the way and clean it up from there.
It's probably it great shape overall, but I can't imagine leaving some of that dirt/grime inside the engine.
Good luck
BlwnLs1GTO is offline   Reply With Quote
Old 07-27-2015, 01:38 AM   #22
RonSSNova's Avatar
Just finished disassembling an 80k mile 5.3. Looked very nice on the outside.
Was replaced because of white goo under pass side head.
The pan had at least 2" of grey/black paste in the sump. There was a divot where the pickup sat. Ha!
Glop came out of the filter. Sludge city under the valley cover.
Rod and main bearings were perfect! Bored excellent. Pistons fine.
Amazing.
I saw evidence of a weeping head gasket. Cam bearings pitted.
Will go back together with a few new gaskets, LS1 cam and a turbo.
Ron
RonSSNova is offline   Reply With Quote
Old 07-27-2015, 08:55 AM   #23
Amazing.
Ron
That is crazy that none of the rod bearings had an issue.
I was going to pull the heads and check the cylinder walls. If they look good. I was going to leave the rod and main bearings in place.
This motor isn't really sludgy it just had a layer of mud on it and in the valley cover. The truck it came out of was a railroad truck. Strictly dirt road driving only
One thing that is kind of weird is that the front (the first three)rockers and push rods have a layer of rust on them. Any ideas what would cause that? I'm assuming pressure washing without covering things.
capriceutah is offline   Reply With Quote
Old 08-16-2015, 08:32 PM   #24
Passenger side
Driver side
Well looks like a full rebuild is in order. What do you guys think?
Old 08-16-2015, 10:00 PM   #25
redbird555's Avatar
I'd be hauling that thing back to the yard and demanding a new engine if I were you
redbird555 is offline   Reply With Quote
Old 08-16-2015, 10:05 PM   #26
DietCoke's Avatar
^bring it back
DietCoke is online now   Reply With Quote
Old 08-16-2015, 10:21 PM   #27
I bought it from a guy.. No yard to take it to. He is going to refund me some of the money
Old 08-17-2015, 02:04 AM   #28
How did they wreck it on a dirt road?
That sucks, maybe it's time for a 408!
BTW very cool engine puller
oerllikon is offline   Reply With Quote
Old 08-22-2015, 01:10 PM   #29
Well the guy is a true scumbag. I'm going to be rebuilding this motor. Hopefully it wont need too much
Old 08-22-2015, 01:54 PM   #30
Quote:
from your previous post, you went from "I bought it from a guy.. No yard to take it to. He is going to refund me some of the money" to "true scumbag".
Can we assume that the seller decided to not refund any of the money at this point? Or did something else happen to lower the sellers status?
scout2000 is offline   Reply With Quote
Old 08-22-2015, 02:22 PM   #31
Yep, no money for me. He decided there were way too many "variables". To be fair I have had the motor for a month and half. I work out of town a lot and have two small kids, so time is tight. I has been stored in my garage on a stand since the day I got it. He went from it ran well in his ad and was maintained well to how was I supposed to know it was bad. He also said he gave me a fair price. I agree if the motor was what he said it was. It would have been an awesome price There is no way that motor ran well with the rust in the cylinders like that. The head gaskets slid off in one piece, so I think both of them were leaking. I cleaned the cylinders out with blue shop towel and WD40. It looks a little more promising than earlier pics but it will need some machine work I'm sure
Oh well. Lesson learned
Old 11-22-2015, 06:15 PM   #32
I know if has been a while since I have posted on this.
I have been tearing the motor down and the bottom end looks perfect. The bearings look new. The crank looks perfect also.
Once cleaning all of the mud out of the cylinder walls. I think I might be able to do a quick ball hone job. I'm going to have the block hot tanked etc and see where I'm at after that
Old 06-01-2016, 08:02 PM   #33
What is the current status on your 6.0?
Old 06-02-2016, 03:59 PM   #34
smws6ta's Avatar
whispers....403...408.....time..
I picked up my short block for $200 from an auto salvage. At first it was $300 till I tried turning the crank over in front of them and then it dropped to $200. I got it home knowing it was going to be torn into anyways. Pulled the pan and windage tray and found #8 piston rod looked like a pretzel. I figure it had been from a hydrolock. So I had my machine shop look it over and had them bore them out to 4.005" I was in a hurry at the time and trying to get it back together. Long story short...on test drive I had rod bolt failure and it ate the crank and several bearings. Lucky my cam survived. So it's now a 403ci.
smws6ta is offline   Reply With Quote
Old 06-02-2016, 10:23 PM   #35
I never went any further with it. I was half temped to hone it and throw it back together. It is still in my garage. I have everything I need for the swap
It is supposed to go in my 95 caprice wagon that lost its built 4l60e today.
Not sure what my next plan is. I travel for work a ton and have smaller kids. I just haven't had a lot of time.
Old 03-19-2017, 07:22 PM   #36
I'm not giving up on this thing quite yet. I ran a ball hone through it(400 grit) last night and cleaned up well I think I'm going to slam it together and run it. I can drag a fingernail and nothing catches.
Old 03-20-2017, 11:22 AM   #37
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Nice.
mOtOrHeAd MiKe is offline   Reply With Quote
Old 03-21-2017, 12:02 AM   #38
CattleAc's Avatar
Glad to see your back at this.
Check those cyls that had a lot of water in them for cracks...after that...put it together and beat on it like it wrote you a bad check...
CattleAc is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Using a 2002 5.7 Van harness to control 6.0 ? capriceutah Generation III External Engine 2 07-15-2015 01:07 PM
New to the LS platform in Utah capriceutah Introductions & Greetings 0 07-04-2015 12:24 PM
New from Utah! could use some help! kelsosv111 Western Members 0 04-21-2015 12:13 AM
New from Utah! kelsosv111 Introductions & Greetings 0 04-21-2015 12:10 AM
Looking for a tuner in NC... 2kx2 Cadillac CTS-V 2004-2007 (Gen I) 21 06-18-2009 11:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
