Got car apart for head/cam, should i install a new timing chain??
So ive got the car apart and the motor on a stand for heads/cam, ive got the ported LS6 oil pump, just trying to take preventative measures....the longblock i bought is used but only has 30,000 miles on it and is VERY clean....should I go ahead and install a new timing chain like a double roller or something? which one would you reccomend? I am going to be running the TSP 225 cam and PP stage 2 race series 5.7 heads. Cam specs are 225/225 .589/.589 112+2lsa. thanks!
brian
brian
I did my H/C swap at 45k. I bought another stocker but when it came down to it I didnt want to drop the pan so I left the original chain. So far Ive got hundreds of passes and 79k and so far so good. If you have the time and motovation, it probably wouldnt be a bad idea to change it. Personally I would put another stocker on. My .02
Originally Posted by Pimp_Nas_T
I agree with Canninbal. If you have the motor out and you're in there anyway, change it with a double roller. It will be a lot easier to do it now than in the car later.
