MMS 220 Build for "Ghost Hawk" - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 07-21-2015, 07:21 PM   #21
redbird555's Avatar
I don't think it's that much more maybe another 6-7hp, turn one is a good mod I have one. I would go to an electric setup if I could find one that reliably works and isn't a hack job but I won't give up ps on my dd lol
redbird555 is offline   Reply With Quote
Old 07-21-2015, 07:52 PM   #22
Super Hulk Smash
JakeFusion's Avatar
Turn One increases feel at speed as well. A little more effort in parking lots, but it also takes a load off the motor. Big cam guys can appreciate less load at low speed to make the car less angry.
JakeFusion is online now   Reply With Quote
Old 07-21-2015, 08:08 PM   #23
Darth_V8r's Avatar
Thanks for the info. I like the idea of getting all the load off the motor but not at the expense of reliability. MAF arrived. Thing is massive. About an inch more diameter than stock
Darth_V8r is online now   Reply With Quote
Old 07-21-2015, 08:09 PM   #24
Darth_V8r's Avatar
Here is the shot of the wire. Comes without a screen.
Old 07-21-2015, 08:21 PM   #25
Super Hulk Smash
JakeFusion's Avatar
Get a screen on there. My TSP has the screen. It makes tuning it 100X easier.
Old 07-21-2015, 08:38 PM   #26
Where do u guys get the screen from for the 100mm maf?
drew408 is offline   Reply With Quote
Old 07-21-2015, 09:11 PM   #27
Super Hulk Smash
JakeFusion's Avatar
Old 07-22-2015, 03:49 AM   #28
Agree 100% on that screen. I mounted mine with JB weld and a q-tip. NEVER had a problem. Mine was screened way before TSP started screening theirs. You don't need quite as dense cell count as the TSP. Next step down is fine.
http://www.hptuners.com/forum/showth...l=1#post193758
See post 24.
Exidous is offline   Reply With Quote
Old 07-22-2015, 04:37 AM   #29
Thanks!
Looks at this,$61 and some change for the 100mm maf sensor housing and Ac Delco ls7 maf!!
Amazon.com: Spectre 9705 4" Polished Aluminum MAFS Adapter Tube: Automotive Amazon.com: Spectre 9705 4" Polished Aluminum MAFS Adapter Tube: Automotive
Old 07-22-2015, 06:24 AM   #30
Darth_V8r's Avatar
cell options are like 4:1, 5:1, etc. What is needed?
Old 07-22-2015, 08:11 AM   #31
Super Hulk Smash
JakeFusion's Avatar
I think he says LS1 standard is 5:1 but either would work.
Old 07-22-2015, 08:12 AM   #32
redbird555's Avatar
I did 6:1 as I found that's what most people use. It tuned just fine with that in there. I went the Amazon specter route though lol I have 100 bucks into my whole 100 maf setup. Send that lingenfelter back
Old 07-22-2015, 08:58 AM   #33
Tuskyz28's Avatar
I got my eye on you.
Tuskyz28 is online now   Reply With Quote
Old 07-22-2015, 09:06 AM   #34
Darth_V8r's Avatar
My tuner specifically recommended the lingenfelter. I don't want to deal with "well if you'd have done x it would be better". This is a no excuses build. Same reason I had the lifters drilled for axle oiling.
Old 07-22-2015, 09:06 AM   #35
scotty2000ss's Avatar
What wheel/tire combo will you be running? Same rear set up that's in your sig?
scotty2000ss is online now   Reply With Quote
Old 07-22-2015, 09:09 AM   #36
Darth_V8r's Avatar
Same rear, etc, for now. I'll be putting a 9" in around thanksgiving time. My rear is already on borrowed time. So's the car's rear.
My tires are 26.2" diameter vs 24.7" stock. My thought was to go 3.89, which works out close to a 3.73, or just say "F" it and go 4.1 to end up at 3.89
Old 07-22-2015, 09:13 AM   #37
Super Hulk Smash
JakeFusion's Avatar
The casing around the sensor doesn't matter. It's the sensor that matters.
But you need to have a screen in there. The intake tract on the F-Body is different and more turbulent than an LS3 Vette/Camaro. So you have to straighten the flow out for the MAF to work.
And the Lingenfelter data provided is a good baseline for the transfer function in the Gen III PCM. You still have to tune the entire intake tract on the dyno. Hold the throttle steady for each cell in the MAF table for 20 secs with the wideband logging. Should take 15-20 mins total.
Old 07-22-2015, 09:19 AM   #38
Are your wheels lightweight? I've been told my wheels rob me of a ton of power and I know when I re dyno'ed after the gear swap (3:42-3:90) I lost quite a bit on the dyno. Not that you don't know this already
Old 07-22-2015, 09:55 AM   #39
Darth_V8r's Avatar
That is the plan. I'm going to leave the MAF disconnected to get to the dyno and then do exactly this.
@Scotty - The wheels are take offs from a 2012 vette. I have pictures of the car on the stock wheels, and it just looked stupid. I'm planning to get the dyno tuning done on the stock rear anyway. I can calibrate the speed sensor anytime and don't need a dyno for that.
Old 07-22-2015, 10:12 AM   #40
Rise of the Phoenix's Avatar
So how soon do you plan to have the build completed? Will you have it done before winter?
Rise of the Phoenix is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Mamo Motorsports MMS220 Build Thread 5_litre_eater Generation III Internal Engine 474 09-16-2016 07:07 AM
N/A 346 Build KLR Z Generation III Internal Engine 92 08-09-2016 12:28 PM
416 LS3 Stroker with MMS 235 cathedral results! Tony Mamo Dynamometer Results & Comparisons 50 04-05-2016 03:08 PM
Ultimate Street Car (On A Budget) bluebird71 Forced Induction 66 10-12-2010 09:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
