Oil priming question
About to start up my lq4 swapped trans am this weekend for the first time. No internal work done just swapped oil pan and accessories over. Do I need to worry about priming the engine? It's say a couple weeks without oil in the pan. If so how do I go about it?
when I built my motor, I used a cheap drill pump hose clamped to where the oil filer screws on and primed with that while someone was turning the crank with a breaker bar. worked pretty damned good, showed like 60psi on the guage.
It gave me a warm and fuzzy, at least.
Sorry, clarification. The engine is not built. It was pulled from a wrecked running truck. So it sat for about 3 weeks with out oil in it on a stand. I haven't touched anything inside the engine.
Its still a good idea to prime it. But if you want to be **** about it, make sure you get oil out of all the pushrods/rockers. ( just like SBC/BBC)
I saw people using a garden sprayer and pushing it in the oil port at the front of the block. But that would only get to one side of the oil pump (right)
how would I get it to the other side?
Moderator
Received 1,835 Likes
Pull the spark plugs and the fuel pump fuse and spin the engine with the starter. Video Link: https://www.youtube.com/watch?v=lGlIu38wcug
