317 or 243
Old 07-31-2015, 03:50 PM
CoreyH's Avatar
Default 317 or 243
I have a set of 317 heads and a set of 243 heads. Which would be better for boost? I have a 5.3 block with flat top pistons. I understand the 317 heads are 10:1 compression and the 243s are higher. Plan on adding boost, but which head will be better for that set up?
Old 07-31-2015, 05:20 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Not on a flat top 5.3. I feel you got it a little mixed up. 317's would put you at 9.18:1 compression. 243 heads would put you at 10:1. It depends on boost level and intercooler/meth as to which way to go.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 07-31-2015, 07:56 PM
CoreyH's Avatar
I read on a forum on here that the compression on the 317s is 10:1. I should have measured that before I took those off.
I broke a rod and I just got a new one and everything is ready to go back together. The cam I am looking at is a 228/235 .608/.610 114+2LSA. I want to turbo it, but probably won't be able to do that until next summer. I want to do this the best way now, so I have a good set up now that is capable of supporting boost in the future. Is that possible?
Old 08-01-2015, 12:08 AM
sawblade99Z's Avatar
That's the compression of a stock 317 headed LQ9.
Old 08-01-2015, 06:23 AM
CoreyH's Avatar
I see that now. I went back to the article and seen the lq9 is the 6.0. So my question now is if I mill the 317s 20thousandths, which heads should I go with? I won't be able to do the turbo setup until probably next summer. I don't have the 243s righr now but I have the chance to swap my 317s for the 243s. So I'm either going to mill the 317s or trade for the 243s. Will the 243s handle turbo with stock bottom end of a 5.3?
Old 08-01-2015, 04:26 PM
Moderator
Darth_V8r's Avatar
Received 1,835 Likes on 1,145 Posts
243 is a great turbo head for a 5.3. It'll lower compression just a bit but flow much better - especially exhaust flow
Old 08-01-2015, 05:55 PM
CoreyH's Avatar
Perfect. I am going with the 243s. I'm going to look into bigger valves and a good port job.
Old 08-04-2015, 08:37 PM
omc8's Avatar
If you are going run a lot of boost , Id go with the 317s
or mill the 317s 30k and you be at 67cc
5.3 61cc
243 64.45 cc
853/241 67 cc
317 71 cc
Quick Reply: 317 or 243
