Springs for a 231/237
What kind of valve springs is everyone using for the TSP 231/237 cam? I need a set that use the stock valve seats, yet are still dual springs and good for this cam.
Dual spring would be recomended, though 918's will work. I don't belive the spring seat is required for the Crang springs, and possibly not for Comp and Patriot as well, but might as well get them if you can, while you have it all apart...
LSxGuy widda 9sec Mustang
You'll have to change/remove the stock spring seats with any dual spring and swap to the earlier style valve seal before they went to the integrated seal/seat configuration. I've used Comp 918's, Manleys, Patriot dual, and Crane dual springs on that cam with no problems.
LS1Tech Premium Sponsor
I'm running the Patriot Daul Springs with the 231/237.
Brian
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
