Best LS6 Stage 2 heads?
Old 06-08-2004, 08:55 AM
SlickVert's Avatar
Default Best LS6 Stage 2 heads?
Who makes the best performing Stage 2 LS6 heads for a stock cubes engine?
Old 06-08-2004, 09:10 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
What's up Bob,
IMO, these are the best (I know, they're not Stage 2 as the question asked, they're Stage 2.5)...
Check out the killer Torque Numbers....
https://ls1tech.com/forums/showthrea...TEA+2.5+torque
AFRs are on sale now too. Would be interesting to see what the initial results of the first batch released will be like.
Old 06-08-2004, 09:13 AM
CamaroCain's Avatar
what size cam do you plan to run and do you have all the other basic bolt-ons?? What are your goals? high dyno numbers or good track performance?
Old 06-08-2004, 10:40 AM
Classic's Avatar
I actually have a set of those TEA S2.5 LS6 heads mentioned above for sale (new).
I'll shoot you a pm with the details.
Old 06-08-2004, 12:17 PM
verbs's Avatar
I have the TEA stg. 2.5 LS6 heads and they are sick!! I would look at either those or absolute speed's heads. BTW, the massive torque #'s come as a result of their special nitrous exhaust port at the expense of about 10rwhp up top. You can choose to gain more up top with less torque should you decide to go with these heads and no nitrous exhaust port.
Old 06-08-2004, 04:19 PM
SlickVert's Avatar
Thanks for the reply's
I am look at going with the FM13. My goals are good track performance with good street manners.
I have all the bolt-on, LT's, 3" ORY into 3.5" then 3.5" cutout, spec III, 12 bolt 4.11, m6, hals, ect.
Old 06-08-2004, 04:23 PM
gomer's Avatar
I ran the FM13, results in the sig, with Patriot LS6 style heads.
Old 06-08-2004, 04:31 PM
bspz28's Avatar
I am running cartek's 3x ls6 heads with their 230/236 cam and I am making 484 hp and 420 tq through a Moser 9" rear and 4.11 gears. 6 Speed with a steel flywheel .
I will say they are one of the best heads out there right now
Old 06-15-2004, 07:51 AM
777's Avatar
anything on mti...i thought they were supposed to be real good
Old 06-15-2004, 08:09 AM
!LS1 11 Second Club
They are good.
Old 06-15-2004, 08:14 AM
LEO
LEO's Avatar
MTI makes some of best heads around. Check out there website to see what is involved in the making of a set of their heads. I believe you will be impressed. They have had plenty of satisfied customers and track times to back up their claims. Many of the tuners are using much larger cams then MTI uses in order to produce high dyno numbers. You can compare flow #'s and will find MTI at the top of the pack. MTI flows all their cylinder heads and provides their customers with the flow sheets.
Old 06-15-2004, 08:24 AM
CHRISPY's Avatar
There are a ton of good offerings from all the sponsors. Do some research and check out the times people are running with the combos
Old 06-15-2004, 08:38 AM
kumar75150's Avatar
i'd have to go with cartek
Old 06-15-2004, 11:49 AM
mike m's Avatar
The best LS6 head for performance and price would have to be Absolute Speed. Just give Lou @ lg motorsports a call. He has been buying these heads for a long time now and has posted some of the highest dynoing 346 cars out there with the AS ls6 heads.
Old 06-15-2004, 11:55 AM
2xLS1's Avatar
When comparing heads, make sure you are comparing apples and apples. There are LS6 heads and LS6 style heads.
