Which timing chain?
Which timing chain?
I'm looking for a chain that will allow me to advance my cam 4°.
What are my options for them and will I need anything odd to install one aside from the usual tools?
Links and info are appreciated.
SN95 Director
im running a rollmaster double, its a damn beefy unit and i have no complaints. alot of people just dont want to swap the new sprocket over since it requires a bit of extra work but its not bad. off the top of my head i dont remember if the JWIS single chain is adj. but its a nice chain too.
TT-TECH Veteran
The Rollmater is very nice although they just went up in price I think it is around $100. The Comp single is quite a bit more I can't remember off the top of my head. You asked is a single chain better than a double not in my opinion. The single just doesn't require the use of two little 3mm spacers for the oil pump, but like JRP said it is no big deal you are already there.
i bought a jwis timing chain, seems to be a nice upgrade over stock, havent installed mine yet, but a freinds using it on his 600 rwhp car and no problems thus this far
Originally Posted by -Joseph-
The rollmaster single in non-adj out of the box. Its just like the stock chain/gears in function, although the chain is probably stronger.
Well damn-the-luck. Are there any single chain adjustable's out there?
