DCR on 93 Octane. How high have you gone?
Have seen threads where guys have gone up into the high 8's DCR on 93 Octane. If you have gone above 8.6 DCR please note what was experienced.
Planning to up ours to 8.82 & can reduce if necessary (adjustable timing set & 2 piece cover). Have run up to 8.6 in the past without issue. SCR will be 11.65...reduced down from 12.0.
AFR 205 heads, 4.030"/.040 Cometics, stock LS6 cubes. Quench is excellent. We ran 29* @ max TQ & 32* after & up to 6800 RPM through carb w/ no pre-detonation. Plan on similar w/ modded set up. Can log A/F ratio & have headphones/mic to listen for knock. So, we will be able to safely dial it in.
Moderator
Received 1,835 Likes
I'm at 8.7 now. Peak power at 24 degrees advance vs 27. Had some KR initially in the off idle range but was able to get rid of it. Peak Tq timing is 22 advanced.
8.96:1 with a really tight quench... About. 033". I have not tuned the wot yet but have not seen any knock yet. I am on RON 98 gas. Roughly equal to ron/mon93.
Cam is smallish. 225/227-114+4 mamo top. Tony expects around 26-28 peak.
What's your quench at? Probably the same as mine.... You'll be fine.
My combo was ~8.9 DCR and ran fine on 93 octane. Peak timing was 26 degrees, and it even ran find on 28 but no additional power. Air/fuel was also 13-13.2:1 for the dyno pulls.
Two things making this possible IMO were the welded chambers enabling some extra metal for AI to reshape them into a more defined hearth shape and tighter quench. It was at 0.033" with the 0.040" gaskets. If not for these mine would have been a KR bomb.
Jason
Jason
Moderator
You could either keep your durations and go wider LSA, or keep the overlap and open up duration. I would go option 2 personally.
Yea if I reduced the 4° advance (hexadjust) down to 2° I'd be at about 8.8:1. Straight up would get me about 8.65:1 and probably carry a little better up top but I'll wait to see how it does as is. Hopefully I can leave it as is and keep as much midrange as possible...
Figured w/ the quench surface area on the AFR heads coupled w/ the tight quench height, could get away w/ 8.8:1. No?
I'd aim for 8.5:1 ~ 8.7:1... but I'd keep overall compression around 11.5:1. That still matters.
Moderator
How are you doing this? Are you swapping cam? cam and heads? head gasket?
It would be helpful for everyone to include which heads are being used when noting their DCR related experiences.
Another small detail that can help is spark plug indexing.
So I should be fine with these planned future changes?
LS3 heads (~69cc stock) milled to 62.5cc, Cometic .045x4.080 gasket, flat-top piston .011 above the deck, 5cc valve reliefs, 4.07 bore, 6.125 stroke, advertised IVC should be near 68. I come up with SCR ~11.3, DCR ~8.8, quench .034 (cold) unless I'm missing something. Each degree I change the IVC moves the DCR by 8/10th's. No plans on spark plug indexing, I thought that was hype except for extremely high compression?
